centering axle in wheel well
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm wondering how to correct an issue. My wheels are closer to the back of the car then front in the back wheel well. When I measure the back tire from the front of the rear wheel well to the tire I get 3". Then when I measure from the back of the rear wheel well to the tire I get 2"? The car has been dropped 1", has UMI LCARBs and Founders LCAs..Still stock TQ Arm..any ideas??
Re: centering axle in wheel well
To get the rear wheels exactly where you want them will require adjustable lower control arms and panhard bar. When you lowered the car, it pushed the rear wheels back a tad with the stock length control arms.
Car: 89 Formula 350
Ok
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Control arms locate front to rear,
panhard side to side,
torque arm to set pinion angle.
Car: 89 Formula 350
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
aftermarket non-adjustable lcas should be the same length as the factory ones. that's why it still isn't centered.
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
