Just finished installing my Spohn Wonder Bar.....!
Old Oct 15, 2012 | 08:31 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So This install provably took me about 20 min tops, from getting the car up to actually getting under the car and bolting everything up.....The only hard part about this was holding my sway bar and tightening the bolts for the at the same time, other than that the wonder fit just perfectly...
Here are some piks...
Old Oct 16, 2012 | 06:39 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Just finished installing my Spohn Wonder Bar.....!
Now you can wonder what this dose....
Old Oct 18, 2012 | 08:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is what it says about the UMI Stering Brace ( wonder bar ) that I bought =
The 1983-1992 third generation steering brace, also known as the Wonder Bar, is designed to tie the front right and left subframe together. This tubular set-up bolts directly under the front sway bar, stiffening the front frame, resulting in improved handling, cornering and overall performance. The steering brace strengthens the chassis, taking stress from the steering box area which is well known as a weak area on any third generation F-Body.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
bryan623
Aug 10, 2015 11:33 AM
SiCkRs
Aug 8, 2015 08:12 AM
