asking for advise
Old Oct 21, 2012 | 11:06 AM
boricua24's Avatar
asking for advise
I will like to know what's best for my 92 maro's suspension , is not for the tracks or racing but I'll like to have the best for her, i have the lowering kit from eibach but what is the best brand and performance for the best ride.
Old Nov 17, 2012 | 06:37 PM
boricua24's Avatar
what's the problem!?
I posted a good question and I got 0 respond, what's the problem with an advise on a suspension for my 92 rs?
Old Nov 17, 2012 | 10:15 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: what's the problem!?
All i gotta say is dont do to much poly bushings if u do ull get alot of vibration if ur looking for a good comfort ride stick to rubber bushings
Old Nov 17, 2012 | 11:48 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: asking for advise
I replaced all the sway bar bushings and the torque arm bushing with all red urethane bushings this summer in my 92 vert. I also replaced the shocks with bilsteins. I replaced all the worn front end parts a few years ago and installed a 9 bolt 327 posi with PBR rear disc brakes and my car handles like a go-cart now. I know your not looking for a track type suspension but your car is a performance car made to handle so it might as well be tight. Stock new shocks will help the ride a lot and subframe connectors are a must. I tightened my vert up so much I cracked the windshield going around corners this summer. Not from a rock but from body flex. It really handles like a go-cart. You can jerk the wheel and it will slide with very little leaning.
Old Nov 19, 2012 | 09:49 AM
boricua24's Avatar
Thank you guys very much for those tips, it helps a ton.
Elephantismo
Feb 13, 2019 12:51 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
bryanwood74
Sep 24, 2015 09:50 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
stalkier
Aug 21, 2015 01:54 AM
