Vertical movement in idler arm
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My steering is kind of wandery, could be alignment, etc, who knows. But I want to cover all the bases first.
I found that my idler arm has a lot of vertical play on the chassis side., but the centerlinks, tie rod ends, and pitman arm are all nice and tight. Im sure they could be improved with new parts, but I dont see any play in them. Is just a loose idler arm enough to throw off the tracking of the car?
Maybe I should put the car on the ground and then look? The car's in the air in the moment, so maybe it's not stressing the joints enough to see any movement in them?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Vertical movement in idler arm
Some movement of the idler arm is normal.
To check the idler arm for wear, raise the car and put the wheels straight ahead. Push on the idler arm as close to the relay rod as possible with a 25lb force. The idler arm should not move more than 1/8" up or down.
Car: 1992 Camaro RS
Relay rod? Is that where it mounts to the centerlink or where it mounts to the frame?
Relay rod = in some designs, the thing that's called the center link in ours
Actually, it's the name of the part for when one there's only one tie rod and it hooks the steering gear to one spindle, and then that other rod goes from the one spindle to the other. Common on trucks, no longer found on cars, since independent front suspensions became standard, but the name still floats around
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm surprised as much as 1/8 inch is acceptable. If it's worn enough that the wheels turn when you move it it definitely needs replacing.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Any movement in the idler arm that can be detected by hand is cause for replacement. Install a new one and you should note NO discernible movement.
Install a new one so that its link to the centerlink is at the same height, relative to the chassis, as the pitman arm's link. This keeps the centerlink even between the two. You can mark the location of the old one and re-install in that location, but there's no way to know, without checking, that the old one was installed at the correct height.
Pretty simple replacement job, and won't require an alignment afterwards.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
the GM tech info is close to the same info. its a simple fix.
Car: 1992 Camaro RS
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
