1LE panhard bar bushings only
Old Nov 10, 2012 | 03:19 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Bar I have the part number..............I'll bet the bar is the same as the control arms as in same as regular but with harder bushings so does anyone know just the bushing number ?
Thanks...........
Old Nov 11, 2012 | 04:18 PM
Re: 1LE panhard bar bushings only
Not to be a twit; but why would anybody in their right mind try to change the bushings in a stock stamped-rubber suspension part? (especially given that it's damn near impossible to change em without destroying the weenie stock part)
A far more realistic thing to do would be to simply replace the whole bar with something .... substantial.
Old Nov 11, 2012 | 05:04 PM
Jetmeck's Avatar
See my sig...........very low mileage car. Wanting something that looks basically stock.
Always one in the crowd.................doh
Old Nov 12, 2012 | 09:25 AM
A way past the dilemma then, being as how that part can be changed out in a matter of minutes, might be to buy the altogether superior part for when you're actively using (driving) the car; put the OE one in storage; and if someday somehow someone somewhere who would actually somehow prefer to see that the stock garbage is still on it is likely to look at it, put it back on for that occasion.
It's really kind of amazing how weenie that stock thing is. The LCAs are even worse (I'd make the same suggestion re. those as well). Either one, you can bend in your hands. You won't BELIEVE the difference in how the car drives when the parts holding the rear end in place are actually ... holding it in place.
Old Nov 12, 2012 | 11:28 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do a quick google search for the 1LE part numbers.
They are the same parts used for any WS6 equipped car.
Old Nov 12, 2012 | 11:53 AM
Guest
Guest
Posts: n/a
True, just 1LE is much cooler and altogether better.
Old Nov 12, 2012 | 03:26 PM
TTOP350's Avatar
Unless you have a B4C 1LE or a very rare 1LE with A/C they aren't "cool" at all..
Old Nov 12, 2012 | 03:38 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
And at that, only the front brakes and baffled gas tank are actually doing anything better than non 1LE cars anyway... Replace and store...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
