Front Control arm mount broken
Old Nov 14, 2012 | 09:40 AM
barrentinec's Avatar
Car: 89 Firebird
Engine: 2.8 v6
Transmission: 5 speed Manual
my firebird was recently in an accident and i cant find the parts i need to put it back together. long story short the driver side lower control arm rear mount bracket is bent and ripped off. and its bolt holes look like the number 8. I can find rear suspension "relocation brackets" bolt on and weld on all day long which would work if it was my rear bracket that was broken but no one has the front bracket. if any one has come across one or knows who would/could make them could you let me know.
Thanks in advance.
Old Nov 14, 2012 | 09:49 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Front Control arm mount broken
i wonder if a junkyard could cut one off for you? might be worth a call to find out?
Old Nov 14, 2012 | 09:53 AM
Car: 89 Firebird
Engine: 2.8 v6
thanks i have made some calls to a few salvage yards ive been waiting on call backs to see if they will
Old Nov 14, 2012 | 10:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Your talking about the front control arms right? And the rear mounting ear for the control arm? That's part of the k member, and its welded on from the factory, its a common failure point if the car is hit in the front wheel area. It would be best to pickup a different k member and swap the whole thing. you could try to weld a new mount on, but it would be difficult to get it right without taking the k member off the car, and at that point, just swap in a different one.
The can be had for under 100 bux about anywhere. Ebay, craigslist, the classifieds here on tgo, ect.
Old Nov 14, 2012 | 10:56 AM
Car: 89 Firebird
Engine: 2.8 v6
yea i just noticed that and was looking at tubular k members made by bmr suspension they have one for 479 bucks im leaning towards that.
Old Nov 15, 2012 | 12:27 PM
BMR Tech's Avatar
Former Sponsor
Well, be careful there. Our $479.95 K-member doesn't have motor mount options...so you'll be left to use engine plates like a race car...not what you want to do for a street car. Also, you will have to use an upper spring perch as well as lower A-arms. So it's not just the K-member. I can certainly give you a good discount on buying all the pieces together though.
- Kevin
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
