lowering by cutting springs
Old Jan 5, 2013 | 01:27 PM
frankensteinGTA's Avatar
Car: 89 GTA
Engine: 94 LT1 with Painless Perf. cam kit
Transmission: 700r4 2100 stall conv. Vette servo
Have a 89 GTA i want to lower without dumping a bunch of coin into. Wondering what people's opinions are of this method. Have heard to do it "right" i'd be looking @ over a grand just for parts.
Old Jan 5, 2013 | 03:58 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: lowering by cutting springs
IMO You'll have to put stronger shocks on it eather way to keep the car from bouncing. Might as well spend the extra $300 or so on springs that you know will drop the car X". Less work too since you'll put them in once instead of pulling out and back in repeatedly cutting the spring bit by bit to get the right hight. But I guess that depends on how low you want to go. AFIK the most drop available from an off the shelf spring is 2".
Old Jan 5, 2013 | 06:47 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I cut a 1/2 coil from the stock front springs on my 91 Z28 and 1/3 coil on the rear springs to get the stance I wanted. I didn't measure before and after but I would estimate about a 1 1/2in drop. Enough to be noticable but not enough that its bottoming out all the time. I also removed the rear isolators and replaced them with a piece of heater hose. Be sure not to heat the spring when cutting(no cutting torch), I used a pneumatic cut off wheel.
Its always a good idea to upgrade to a high quality shock/struts when lowered and get an adjustable panhard bar to center the rear end. I'm still running what ever struts were on the car when I bought it, but I do plan on upgrading to a better shock/struts later. I don't have any problems bottoming out but I don't normally drive it hard. I did have to adjust my panhard bar slightly to get the rear perfectly centered.
Old Jan 5, 2013 | 07:03 PM
Car: 89 GTA
Thanx. A lot of good info there. Didn't think about the rear axle needing to be centered.
Old Jan 5, 2013 | 07:08 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
^ Great advice. Drop in springs are only like $200 plus shipping... the money is in upgrading struts and shocks, solid strut mounts, bump stops, adjustable panhard bar, and LCARB's to get the geometry back to how it should be and making everything work smoothly. If you don't get the spring hot and don't mind taking it apart and putting it back together until you get it right, cutting is a decent method. However, cutting a linear spring does not make the rate go up, whereas some aftermarket springs will have better rates to back up the drop... and aftermarket springs also have predetermined estimates for drop heights so all you have to do is search to get a rough idea of the stance your car will have.
If you do cut them, make sure you cut the exact same amount on each side and index them properly so you don't make things uneven and throw your x-weights or end up with one side slightly off. At the end of the day though, your rear geometry will still need fixed and your handling may suffer from being underdamped at those ride heights unless you ante up the coin to fix all of it.
Old Jan 8, 2013 | 12:52 AM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
Transmission: slugomatic
I cut the springs on my 89 trans am, very close to a GTA. I think I cut Off 1 1/2 coils off the soft side of the spring. Ride height is nice and it still rides nice. I still have the stock panhard bar on so the rear sits a lil bit to one side. still cant tell. Suspension is still all stock for that matter except shocks. people are gonna flame this, But I look at it like this, If chop Foose will cut a spring to get the stance right, I'm gonna do it too. So in short I like it, made it ride a lil bit more stiff, but I like that.
Old Jan 8, 2013 | 10:07 AM
Car: 89 GTA
Thanx. 1 1/2 coils is what some other folks were talkin also. Haven't noticed any unusual tire wear have ya? Also, who is chop Foose?
Old Jan 8, 2013 | 10:39 AM
LHernandezJr's Avatar
Originally Posted by frankensteinGTA
... who is chop Foose?
I think that's Chip's evil twin brother
Old Jan 8, 2013 | 10:48 AM
Car: 89 GTA
Lol. Yeah. Just Googled who he is. Talk about a dream career.
Old Jan 8, 2013 | 10:55 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
chip foose is one of the most talented people I've ever seen , weather its drawering cars to building a car completly from scratch , ever heard of the show overhaulin? and he loves to lower cars by cutting springs.
Old Jan 8, 2013 | 12:22 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I got new Moog HD springs, cut 1/2 coil off front, rears were new hd and were progressive rate, cut 2 coils off the tops of them, and removed the isolator.
225/45/17 front, 26"x10.5/17 rear tires in this pic.
Old Jan 8, 2013 | 12:36 PM
Car: 89 GTA
Nice ride! Luv that paint. That height is just what i'm lookin for.
Old Jan 9, 2013 | 07:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'd be interested to know what the part numbers were on the springs. I have the 5664's and have cut a whole coil off and mine is nowhere near that low. What accessories do you have up front?
Old Jan 9, 2013 | 07:52 PM
Car: 1971 Camaro
Engine: 427
5662s front
635v rear
Old Jan 9, 2013 | 07:57 PM
Car: 1971 Camaro
Engine: 427
In that pic, the car had a L98 engine with a Stealth Ram, headers, no smog pump, but with complete AC system.
Fiberglass hood.
Old Feb 13, 2013 | 08:58 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
nice.
Old Feb 13, 2013 | 09:00 PM
goliath88's Avatar
Engine: 305 tbi v8
you use any other parts to lower your car besides the springs?? Adj Panhard?? lca's?
Old Feb 14, 2013 | 07:59 AM
Car: 1971 Camaro
Engine: 427
In the rear I have adjustable control arms and panhard, with rod ends.
Poly bushings in front, and trimmed to fit poly bumpstops.
Old Feb 27, 2013 | 08:44 PM
Car: 89 GTA
So you did away with the isolator all together and the heater hose slides over the spring so you don't have metal on metal? How much hose do i need? Im hoping for a two inch drop. Will cutting a full coil and removing the isolator get me there?
Old Feb 27, 2013 | 09:47 PM
Car: 1971 Camaro
Engine: 427
Yes, no isolators, about 6" of hose.
What springs are you cutting? The original ones?
Old Feb 27, 2013 | 09:52 PM
Car: 89 GTA
Yes. Cutting the original stock springs. Just removed them today. Thanx.
Old Feb 27, 2013 | 10:00 PM
Car: 89 GTA
The way those isolators are notched to hold the spring makes me wonder what's to keep the spring from moving around after the isolator is removed?
Old Feb 28, 2013 | 05:29 PM
Car: 89 GTA
What shocks did you go with?
Old Feb 28, 2013 | 07:29 PM
Car: 1971 Camaro
Engine: 427
Started with kyb gr-2, just got some bilstiens for the rear, and will be getting some for the front soon.
Old Feb 28, 2013 | 08:04 PM
Tibo's Avatar
Car: 1991 Z28 Vert
The A-arm and K-member are both notched to a degree, you won't have any problems. For cutting I have heard that cutting a coil by thirds is the best way to do it. so you would cut 1/3 or 2/3 or one whole coil.
Old Feb 28, 2013 | 08:34 PM
Car: 89 GTA
Howd the kyb' hold up? Found some gr2s on the summit site for just $23 each. Sound like the same ones?
Old Feb 28, 2013 | 08:40 PM
Car: 1971 Camaro
Engine: 427
I never put much mikes on them, but seemed fine. Fronts have less then 50 Mikes on them.
Price sounds right for rears.
I'll be selling my fronts in a couple weeks.
they are decent for the money, IMO.
Old Feb 28, 2013 | 08:54 PM
Car: 89 GTA
I might be interested if they would fit a 89 gta. Send me the part# if you have it and how much you want for them.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 11, 2015 09:02 PM
