Recommend torque arm and sway bars
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Hey guys, the only other components I need to change suspension wise are the torque arm and sway bars. Though I'm not really convinced I need new sway bars.
Regardless, those that have swapped these, any recommendations?
Car is leaning more towards road racing.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Recommend torque arm and sway bars
BMR or UMI would be my first two picks; both of which are site sponsors. I personally went with BMR, but I also have a few UMI parts on my car and they're equally decent in quality.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
BMR makes great stuff...i use spohn, but always have. Ive always liked bmr 's fitment and quality. Never used UMI.
Hey there! What are you looking to do with your car? Sway bars are a great part for someone looking to improve highway feel and cornering performance. You'll see a very noticeable boost in confidence when you enter a corner since body roll will be virtually eliminated.
- Kevin
- Kevin
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
As sway bars really don't go bad and the factory made quite a few different sizes, you could get factory bars with new bushings and end links - if you budget won't allow for new.
TQ arm is a definite - the factory one was terrible and not much can be done to make it anywhere as effective as good aftermarket offerings.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I would look at how the car currently handles (first of all, follow Paul's advice and get poly bushings/endlinks for the sway bars). If it oversteers too much, go with less bar in the rear or more bar in the front, if it understeers, go with more bar in the rear or less bar in the front. This depends on your spring setup, weight distribution, etc. Getting cheap used ones to test it out is a good cheap way to do this too. I have stock 34mm front/24mm rear with poly end links and bushings and they do the job (I painted them so that they look good)
Cool, thanks for the tips guys.
Anyone remember which company makes subframe connectors that are in the middle of the chassis? I really don't want to cut up my exhaust.
Alston or MAC (you lose a slight amount of ground clearance though, but nothing too dramatic unless you are very low, or as other members on here put it accurately: stupid low .. lol)
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I installed UMI and I am definitely satisfied. A couple of minor tweaks and adjustments and feels like factory but better.
On a side note, I have a non-adjustable UMI torque arm which served its purpose well but now I am in the market for an adjustable crossmember mounted one. This would add performance and rigidity and I would be able to adjust the pinion angle to reduce driveline vibration/noise.
Kevin (BMR Tech), do you know if the bushing that comes with your torque arm has the lips facing towards or away from the driveshaft?
(Non adjustable)
(Non adjustable)
New2Chevy
Sep 28, 2015 12:35 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
