Hotchkis feed back
Old Feb 14, 2013 | 12:16 PM
Podium's Avatar
Hotchkis feed back
Anyone running Hotchkis springs? I need to buy lowering springs and only have experience with eibach(which I will not be buying again).
Also looking for other input on other options other than eibach.
Old Feb 14, 2013 | 12:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Hotchkis feed back
Gloal west has a good setup too
Old Feb 14, 2013 | 02:21 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Yes - I just got a set of their springs that will be going in soon - good quality stuff without that much of a drop...
Old Feb 14, 2013 | 03:06 PM
Podium's Avatar
Ill have to check out both. Gotta find a good store to order from
Old Feb 14, 2013 | 04:53 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I've had the Hotchkis 1903 1" lowering springs for years. Here's a pic
Old Feb 14, 2013 | 08:03 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
The cars use makes a big difference in what springs you'll want. For example, I quickly overlooked hotchkis cause of the low spring rate. I think it was like 600#-650# fronts. Whatever it was I didn't even write in down in my spring shopping notes. I like to autoX so I need higher spring rates and all linear springs. I went with ground control weight jacks. They were a perfect for MY build. I'm curious to know your eibach story because they were one of my final choices. I wanted a sportline stance but the rears were way too soft for me.
Old Feb 15, 2013 | 08:38 AM
paul_huryk's Avatar
One gripe about the Hotchkis springs is their prices, much more than Eibach or Global West for a set.
Keep in mind that some springs have linear rates, others progressive. If that makes a difference for you, your choices will be more limited...
Old Feb 15, 2013 | 12:06 PM
Podium's Avatar
I dont like Eibachs because they ride so hard and the rear end is jumpy. I liked they handled on a smooth surface. I want it to lower the car, improve handling but not ride like a rock.
Old Feb 15, 2013 | 02:47 PM
Car: 92 Camaro RS
You may like the hotchkis if that's your opinion of eibach. Did you have sportlines or pro kit? What shocks/struts are you running?
Old Feb 15, 2013 | 05:22 PM
Car: 92 Camaro RS
Old Feb 16, 2013 | 10:01 AM
Podium's Avatar
Ive had then sportlines on a 3rd and a 4th gen. Rear end was way to jumpy. Bilstines in the rear and qa1s in the front on the 4th gen and bilstiens all around on the 3rd.
Old Feb 16, 2013 | 01:36 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if i remember correctly, hotchkis rears are about the same rate as sportlines.
Old Feb 16, 2013 | 08:33 PM
meangreen92's Avatar
Car: 91 Formula
have you looked into BMR? They should have a kit for 3rd gens. My 02 TA had a set of 1.25's which actually settled down between 1.25-1.5 which was good for my DD, handled well except for my bad choice in strut/shocks(KYB AGX adjustables).. they were pure crap
89GTAOz
May 16, 2020 09:31 AM
beachrodder
Aug 25, 2015 08:05 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
