Wanna modify the frame next to the exhaust
Old Mar 5, 2013 | 10:23 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am trying to make a 3" y-pipe to single 4".
I may have to modify the frame rail next to the exhaust.
Would it be possible to cut out the frame piece, and then weld in a piece of 2"x2" square tubing? Or could I just cut the piece out and weld a piece to box it in.
This where I have to cut it, see where the black marker is?
https://www.thirdgen.org/forums/atta...1&d=1362543650
Old Mar 5, 2013 | 11:22 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Wanna modify the frame next to the exhaust
Do you want it to have the curve like in the photo
Old Mar 5, 2013 | 11:25 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Now that I think about it, I guess I could square it off, and then box it in.
Would I compromise the strength of the frame?
I have SFC, btw.
Old Mar 5, 2013 | 11:41 PM
Engine: LQ4 ls 6.0
You could do it both ways if it were me and I have done this many times this is what I do every day I would get a 1 foot of thin wall mild steel and have it bent in a pipe bender to that shape then cut it in half then start to trim it until it is close then weld it in and grind it to fit the rest of the frame it will look a lot better then boxing it in just make sure you have close to the same gage metal as what to frame rail is so it will weld together even
Old Mar 5, 2013 | 11:42 PM
Engine: LQ4 ls 6.0
I have SFC, btw.
Not if you have good welds and the same or even heavier gage metal
Old Mar 12, 2013 | 10:41 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Do you have any pics of your modified frame?
Old Mar 12, 2013 | 11:15 PM
Engine: LQ4 ls 6.0
I'm using a I pad and I can't load photos ??? I should have my desktop fixed by the end of the week then I can send you some picures but I found one here this would be done the same way you would do yours http://www.google.com/search?q=modif...RNHcdz_JglM%3A
Old Mar 12, 2013 | 11:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
What I did.
Old Mar 19, 2013 | 08:57 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Can you post any pics?
Old Jun 10, 2013 | 09:51 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Here's what I did.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
