Rear Sway Bar Bushing 92 RS
Old Mar 6, 2013 | 11:45 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
My car is a stock V6 RS. I measure the rear sway bar at 18mm and everything I find in a search here says stock is 18mm. But, looking for new bushings and everybody seems to list only 19mm bushings. Anybody know where I can get 18mm bushings or will the 19mm bushings work fine without being too loose. Doesn't do much good to put in new ones if they end up being loose.. Going to pull it apart and replace all the rear bushings (control arm bushings too), coil springs, and change the fuel pump out so want to round up all the parts first and do everything all at once. Thanks..
Old Mar 7, 2013 | 12:09 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Rear Sway Bar Bushing 92 RS
Energy-Suspension has a ton of sizes! a quick search...
http://www.autozone.com/autozone/acc...er=356002_0_0_
Old Mar 7, 2013 | 10:16 AM
BMR Tech's Avatar
Former Sponsor
I would encourage you to take another measurement of your rear bar. All of my records are showing 19mm as the smallest bar size for the rear on those cars. Best way is to get an 18mm crescent wrench and a 19mm crescent and see which one fits over the bar. Anyway, I was able to locate what you might be looking for on an Energy Suspension site I always refer our customers to. The prices are excellent.
Rear Sway Bar bushings
Let me know what you come up with. There is a chance you may not have the original rear bar on your car. If you conclude that it is indeed an 18mm bar, call up energy suspension. I'm sure they have one that works.
- Kevin
Old Mar 7, 2013 | 10:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following, FWIW, shows 18:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
Old Mar 7, 2013 | 02:47 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Checked the measurement three times and I am using calipers. Measurement is 17.9mm consistently so 18mm. The above thread lists an 18mm for the 92 v6 RS. I have owned this car since 93 and bought it with 20,000 miles. I doubt the rear bar was changed in the first 20,000 miles. I have never changed it. ES didn't show an 18mm.
Old Mar 8, 2013 | 07:31 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
LarryD, you aren't going crazy. I also have an 18mm rear sway bar on my 91. I just bought a sway bar bushing kit for a 19mm rear bar. I'll be putting it on soon. 1mm is less than 1/16". If the bar is centered in the bushing thats 1/32" gap all the way around. Not much to worry about if you ask me.
Old Mar 8, 2013 | 12:48 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
That was what I was thinking too since nobody seems to make an 18mm. I was trying to decide between the 11/16" (17.5mm) and the 19mm. What concerned me was if the factory had put in the wrong bar (ran out of the correct ones) when it was built.
Old Sep 8, 2013 | 07:48 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Just a quick bump.. Has anyone found an 18mm bushing that will work??????? I am surprised there isn't an aftermarket 18mm specifically for the RS. I have seen a lot of them now in the pull a part yards and all have the 18mm bar.. Have found a Prothane 18mm that looks close but don't know if it will work yet or not...
Daily driver so staying with the softer ride but did go to urethane bushings in the rear (except can't find an 18mm for the sway bar)... By the way, they do squeak even though they were greased with the stuff supplied from Energy Suspension with the bushings....
Old Sep 9, 2013 | 10:33 AM
Use the 11/16".
The difference between that and 18mm is a shade under .020"; about the thickness of a business card. I.e, if the difference is HALF THE THICKNESS of such a card. About the thickness of a sheet of heavy copy paper.
Talk about "measure with micrometer, mark with chalk, cut with axe".... this surely is a good example.
DON'T use one that's too large. The bar will constantly rattle around in it, and you'll spend the rest of the time you own the car trying to figure out what the strange banging noise is every time you drive over roads that are smooth on one side of the car but rippled on the other.
I've got a half-dozen cars sitting in my driveway right now with those bushings in em, both ends... NOT ONE sqweeeeeeks. I don't even know how to MAKE EM sqweeeek.
OF COURSE there's not some "universal" part made "specifically for" your car, or for anybody else's. That's why they make "universal" ones in incremental sizes" that way, it fits EVERY car, just like it does yours.
Old Sep 11, 2013 | 11:29 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Well, sounds like the 11/16" is the best way to go if I can find them again..
I used plenty of the silicone grease and the diff has been powder coated so they rub on a smooth surface (maybe too smooth). Going over bumps both sides squeak on the control arms. Maybe it will get better with time but very noticeable right now.. More of a squawk than a squeak.......
Old Sep 11, 2013 | 05:59 PM
Use the "greasable" bushings. Keep em packed. Personally I use regular Mobil1 red grease, no sqweeeeeks on any of my cars & trucks that are so equipped and maintained.
You can always order em from Summit et al. if they're not hanging on cards in the aisle at the store down on the corner.
Old Sep 11, 2013 | 11:05 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
The ones currently making the noise are the control arm bushings and those don't come in greaseable. Also, the 11/16 inch urethane bushings don't come in greaseable either that I can find...
Old Sep 12, 2013 | 06:35 AM
A brief search turned up these; no doubt there are others...
http://www.summitracing.com/search/d...er-in/0-688-in
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
