Springs for back end to raise it up?
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
Ok before u say get oem replacements and that will stop it from sagging, I already did. Néw shocks as well.
My question is are there springs from a different car that are taller and will raise the back End up a little? I don't want to use air shocks cause it will probably punch a hole thru the thin sheet metal.
So yea any suggestions?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Springs for back end to raise it up?
How low is it sitting? Do you still have the isolators installed which give it an inch or so extra height
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
1) See if you can find some thick spring isolators (they were all over the place for sale 10 and more years ago). That should be good for an inch.
2) Think about reinforcing the rear shock mounts. Putting some plate on there should do it.
Good Luck.
Good Luck.
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
^That. Or you can always try the Allstar weight jacks.
http://pitstopusa.com/i-5066715-alls...uster-nut.html
Engine: 4++,350 & 305 CIs
You follow the instructions or you can use google.
Its really simple.
Its really simple.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There are actually 2 different specs for replacement rear springs. If you didn't get the Cargo Coils, then sell yours and upgrade.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I can attest to this.. Raised mine to 29" from ground-to-center-of-fender height on the rear with MOOG 5665 and 4th gen isolators.
toronto formula
Nov 10, 2015 06:17 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
