Rear sway bar link bolt
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
I am replacing my rear sway bar link bolts. All the replacements I see, say 19mm, 21mm, 23mm, and 24mm. How do I tell which size I need? I can't find anything online that should tell me what size I need.
Thanks for the help!
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Rear sway bar link bolt
The rear sway bar will come in different mm sizes. The sway bar link bolts should come in a standard "sway bar kit" and doesn't reference the mm size.
Those #s look like sway bar diameters. They are not related in any manner way shape or form to the bolt length.
You don't replace just the bolts; you replace the whole thing.
http://www.summitracing.com/search/d...s-included/yes
Ones that are about 2½" or 2-5/8" are about right for these cars.
You can also pick em up at AZ and such, hanging on cards in the "performance" aisle.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
