1987 iroc lower control arm relocation brackets
Old Apr 14, 2013 | 02:31 PM
sheldon87cam's Avatar
Axle/Gears: 373
hi guys after just lowering my iroc back on the ground after a full ground up restoration , i have a few questions , i stalled lower control arm relocation brackets on rear axle and used lakewood lower control arms and lowering springs i noticed that the car is sitting high in the back compared to the front , the car has engine and all drivetrain back in vehicle as well as hood , the rear of the car does not have the rear hatch , bumper or interior in car will the weight of the rear hatch lower the car some , as now car seems light in rear and very bouncy up and down with out much force to bounce car , i quess my question is will the relocation braclets raise the rear of car , i used the first set of hole closes to axle or will the rear hatch weight and other items bring car down in rear some , it is a bout 1 3/4 higher in rear than front thanks sheldon
Old Apr 14, 2013 | 07:43 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: 1987 iroc lower control arm relocation brackets
no, relocation brackets shouldn't effect the height of the car. the hatch is heavy, all the stuff you mentioned will make a little difference in height.
Old Apr 15, 2013 | 07:07 AM
The hatch is about half the weight on the rear axle.
Put it back and things will change ALOT.
Old Apr 15, 2013 | 07:21 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Agree with everyone, hatch will make a big difference, gas does as well.
Do you have new shocks?
What springs did you use?
Old Apr 15, 2013 | 08:56 AM
Axle/Gears: 373
i used a new set of rear shocks i think its spelled tyrco and eibach lowering springs , lake wood lca and adjustable pan hard bar , thanks you guys for your replies sheldon
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
