Rear end shimmy
Old Apr 23, 2013 | 04:49 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Rear end shimmy
Interesting little problem developing. My rear end has a shimmy in it. At certain speeds, types of road, etc. the rear end bounces back and forth. Some places it is VERY noticeable, others it is more subtle. I know the bushings for the panhard bar, and LCAs are shot. Could that be the problem? What else might cause this? Iv been driving the same roads for a long time and this is something that recently started. Any ideas????
thanx in advance.
Old Apr 23, 2013 | 07:00 AM
Re: Rear end shimmy
Of course, if the parts whose job it is to hold something in place are wore out, then they might not be doing their job. Replace those first. I'd suggest replacing the entire LCAs & PHB instead of trying to mess with bushings. I'd also STRONGLY suggest new poly sway bar end links & bushings, and new springs & shocks. Basically replace ALL the worn-out wear parts and see where that leaves you.
Old Apr 23, 2013 | 04:22 PM
Veaceonee's Avatar
Re: Rear end shimmy
Iv been strongly considering getting that Founders Performance rear end kit. What size sway bar bushings should I get for the back (Im guessing for WS6)?
Old Apr 23, 2013 | 05:43 PM
Re: Rear end shimmy
Whatever size your sway bar is... measure it.
Old Apr 23, 2013 | 07:04 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: Rear end shimmy
Check axle flanges and wheels.
Old Apr 23, 2013 | 07:45 PM
Re: Rear end shimmy
Axle flanges are the same no matter what the sway bar size is.
Wheels are eeeeeeeeeeeezy to change and therefore carry no identification information.
Go directly to the thing you want to measure, and measure the thing you want to know, if you want to know the measurements of something. Otherwise it's a bunch of guessing.
Old Apr 23, 2013 | 08:10 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Rear end shimmy
GTA's came with 24 mm rear sway bars.
Old Apr 24, 2013 | 06:14 AM
Veaceonee's Avatar
Re: Rear end shimmy
WEll, I think I found my issue, and it aint pretty. My right rear tire has a HUGE bubble in it. I am thinking that is the cause. Put a little air in it (from 35-40 psi) and it made it worse. I am guessing it is that tire.
Old Apr 24, 2013 | 06:51 AM
Re: Rear end shimmy
Well, that's cheeeep and eeeezy then; and of course, something that has to be done from time to time anyway.
Sounds like time for A SET OF tires.
Definitely consider the sway bar pieces, springs, & shocks, as well. The other parts may not make much difference; but replacing those particular routine-maintenance parts can REVOLUTIONIZE a car.
Old Apr 29, 2013 | 01:57 PM
85 ZXX's Avatar
Re: Rear end shimmy
I had a bent axle flange and my wheel wobbled alot. A friend spotted it as I was driving down the road. Good to hear that you found the problem.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
