Founders performance LCA + Panhard kit
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I am considering this purchase. Anyone already have them installed? How are they?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Founders performance LCA + Panhard kit
Quality is nice. I got the single adjustable setup and was very impressed with the fit and finish, especially for the price.
I put a set in this spring along with sway bar bushings and links and a wonder bar, cut down a lot of squeaks and rattles and it feels much better on the road.
Installed pretty easy, and looks better then the old bent rusty stamped steel stuff
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I have a few Founder's parts. They seem to me to be the same quality as UMI or BMR, but for a more reasonable price.
Car: 82 Sport coupe
they worked out amazing perfect fit
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
All you guys who have put on a panhard bar, is it better to replace it on a lift or with the car just sitting on the ground?
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
I had a lift available so it was easy to change the control arms and panhard bar, but if a lift isn't easily accessible then it can be done in the driveway. Really just depends if you wand to roll around on the ground or not.
As said, only difference is whether you get to do it standing up, or have to lay on your back.
Car: 1983 camaro Z28
Engine: SBC 383 stroker
Transmission: TH350 2800 stall manual valve body
Axle/Gears: 7.5 10 bolt 3.73 Posi
Jus ordered mine last Thursday and received em on Tuesday fast shipping and quality and craftsmanship superb Jus as good if not better than BMR,UMI, Sphon, Etc...
ambainb
Apr 25, 2016 09:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
