Bent LH Control arm why?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Found this today, my LH rear control arm was bent upwards.
Any ideas why?
/N.
Any ideas why?
/N.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Bent LH Control arm why?
Because of a poorly designed component. The adjuster should never be in the center of the arm like that.
^ yup, junk parts
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
set on Fail..with that one.. ouch!
good bite at the track?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
What brand is that one? Not that it really matters what brand since a single adjustment point in the middle is a bad design whoever made it. Also the reason I bought LCAs & PHB that have adjusters at the ends.
The good news on yours is that the tubes appear, in the pic, to be fine & you might be able to get away with only having to replace the adjuster piece in between the tubes.
But I would switch designs regardless, even if you did just replace the piece for now & svaed up for new LCAs. How many passes are on those?
Car: 87' IROC
We had an interesting discussion a month or so ago about this kind of design on a panhard rod. I argued it was a bad idea due to this kind of problem. If only I could find that thread, your picture would be great to add.
John
John
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Its Spohns LCA...
The tubes are OK, so I'll will straighten the adjustment bolt until I get a new one shipped.
The swaybar is also from spohn.
OK, I will think about getting another design later but will go under the car some more this weekend and look closer for something "odd".......
/N.
/N.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
DO NOT straighten out that adjuster and run it like that... that's an almost guaranteed way to cause it to break... it's junk- throw it out..
Car: 86 Camaro
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
We have these in stock....
http://www.midwestcontrol.com/part.php?id=1518
And while your at it, I see you are running poly double adjustable's. Look at these, double adjustable poly arms (with the adjustment point where it should be...)
http://steinjager.com/shop/index.php...ix=&tierSeven=
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its Spohns LCA...
/N.
/N.
Car: GTA
Shouldn't take but a few days to get a new adjuster mailed to you. State Inspection is not worth wrecking the car or somebody elses car if it failed on the road.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
