is my k member bent?
Old Jun 15, 2013 | 02:51 PM
Hubes's Avatar
Car: 85 Z28
My passenger side front tire is pushed back 1/2"-3/4" inch farther than the driver side. I cant see anything obviously bent, I had the a arms off over the winter for new bushings and ball joints and they looked fine. the only thing I can think of is maybe the rear pocket for the a arms is bent a little. does anyone know how I could tell, or maybe have any other ideas? thanks
Old Jun 15, 2013 | 06:24 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: is my k member bent?
the framerail could be pushed back from a previous accident.
Old Jun 16, 2013 | 07:51 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
The rear control arm mount for the k member are spot welded onto k member in like 3-4 spots IIRC I've seen som crack along the welds
Also check to see is strut isn't bent some way but I doubt it ..
Only other issue is frame is bent like stated above
Old Jun 16, 2013 | 08:20 PM
How did you measure this?
I assumed you trammed the car and checked the wheels for being in a square, right? Not just compared them to the fenders or to some similar randomly shaped piece of trim?
Old Jun 16, 2013 | 09:48 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Forgot to ask that
Old Jun 16, 2013 | 10:30 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My first thought was that the new k member could be off from manufacturing and not "bent.". Was this disproved already?
Old Jun 17, 2013 | 03:32 PM
Hubes's Avatar
Car: 85 Z28
I measured the wheelbase using a measuring tape, driver side is 101" and passenger side is less. the welds are definately not cracked. its not a new k member. the k member did seem a little farther back on the passenger side, so I loosened the bolts and pried it out a bit but I only got it to move like 1/8". Perhaps a good question is, if it seems to drive fine is it a problem?
Old Jun 17, 2013 | 04:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I guess I am confused. Is this a new or new to you K member or is it your stock K member?
Old Jun 17, 2013 | 04:55 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
stock
Old Jun 17, 2013 | 07:05 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
too much caster on the one side will move the wheel back farther than the other side... and did you measure to make sure that the rear end is in the car square?
Old Jun 17, 2013 | 07:49 PM
So, how do you know the front wheel is the one that's moved?
What are the "square" measurements? (RF - LR, LF - RR)
How is the car aligned? You ARE aware of course, that in these cars, adding caster, moves the wheel rearwards?
Old Jun 22, 2013 | 11:50 AM
Hubes's Avatar
Car: 85 Z28
I think I fixed the problem, or at least mostly. I noticed the k member was closer to the subframe on the passenger side, so I loosened the k member bolts and pried it forward a bit on the passenger side, now the passenger wheel is only 1/4" farther back, which could possibly be fixed with an alignment. If not its probably close enough.
To answer sofas questions, I figured it was the front moved because it wasnt in the middle of the fender (I know bad reference) and the front would be more likely. Would a bad alignment cuase 3/4" difference? I know it would move it a little, but the ball joint doesnt move so really how far can caster move it?
Old Jun 22, 2013 | 05:08 PM
ALOT.
Look at the slots on top of the strut tower... it can move THAT MUCH.
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
Zell1luk
Sep 29, 2015 10:36 AM
