Are all A Arms from 82-92 the same?
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Looking to swap out my 15" inch wheels for GTA 16" wheels. I am looking at also putting in new delrin bushings so I decided to see how much $$ I can get an A-arm from a junkyard. Looking at car-part.com it shows that there are different a arms for 15" and 16"
I was not aware that A Arms were made differently... What A Arms should I try? I have the stock Delco 10.5 brakes.
I found these choices off of car-part.com
1992 Pontiac Firebird
Control Arm, Front Lower
15" whl Right
15" whl Left
16" whl, perf pkg (opt 1LE) Right
16" whl, perf pkg (opt 1LE) Left
16" whl, w/o perf pkg; tire opt QLC Right
16" whl, w/o perf pkg; tire opt QLC Left
16" whl, w/o perf pkg; tire opt QPE Right
16" whl, w/o perf pkg; tire opt QPE Left
15" whl Right
15" whl Left
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Are all A Arms from 82-92 the same?
Thanks James!
Would the 1LE A Arms be worth the hunt ??
__________________
__________________
I'm not aware that the 1LE is any different than any other a-arm with a 16-inch wheel. Even the 1LE spindle is simply modified from a regular spindle.
JamesC
JamesC
Kind of strange that they delineate 1LE specs on their search engine .... What's up with that?
I've noted that where car parts are concerned, there's a lot of misinformation floating around the auto parts stores.
JamesC
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
^ like how on places like ebay the same part listed for Camaro / Firebird will be $20 more then the same part listed for S10 / S15
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
It was my understanding that all the arms are dimensionally the same, with the exception of the steering stops. These are different to prevent tire to frame/body interference with the different wheel/brake offsets.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
And you are correct. People shouldn't read too much into how the parts for these cars are listed in current catalogs. Plenty of errors there.
I think the link I've posted above covers most everything.
JamesC
JamesC
Car: `86 SS / `87 SS
Would 25 year old 1LE bushings be superior to new Delrin del a lum bushings?
Vintageracer
Sep 24, 2017 12:34 PM
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
