ragjoint
Old Jul 11, 2013 | 03:08 PM
rx8camaro's Avatar
ragjoint
so I have upgraded my steering box to ARG and pump as well. Billet 12:1 box. Now I need to fix my ragjoint. I would like a very high quality aftermarket one. I tried flaming river but guy on phone told me they only work with flaming river steering columns? is this correct? Anyway if anyone has one they recommend that would work for me just give me part number. Thanks. Car is a 1992 Camaro Z28 5.7 auto.
Old Jul 11, 2013 | 04:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: ragjoint
Search this site for Jeep or Astro van steering shafts.
Old Jul 11, 2013 | 06:20 PM
BADNBLK's Avatar
COTM Editor
Re: ragjoint
Agreed! I basically just put on the same box, and I used a Jeep shaft, and an Astro van bearing conversion. I bought mine from a member here... MCClover? Something like that. Very easy installed and when you remove your old unit you will wonder why it was not like this from the factory.
Check the classified section for posts of member selling them.
Old Jul 11, 2013 | 07:09 PM
rx8camaro's Avatar
Re: ragjoint
thanks again I will look into that.
Old Jul 11, 2013 | 07:34 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: ragjoint
i got a jeep from a member here awhile back
cleans up engine bay a bit also
https://www.thirdgen.org/forums/susp...ing-shaft.html
Old Jul 18, 2013 | 01:46 AM
87350IROC's Avatar
Car: 87' IROC
Re: ragjoint
No, there are many of us on here using the flaming river parts with the stock column.
Old Jul 18, 2013 | 10:17 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: ragjoint
I have a flaming river shaft and ujoints (both sides of shaft) and it works well
HPE
Apr 30, 2007 12:30 PM
Zap Racing
South Central Region
16
Feb 8, 2006 02:19 PM
Lostsol
Nov 21, 2001 12:08 PM
MIG-29
Nov 14, 2001 02:50 PM
Lostsol
Dec 1, 2000 09:43 PM
