installed a 9bolt sits lower in the rear
Old Jul 31, 2013 | 10:07 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
ive noticed after doing the 9bolt swap that the car sits lower in the rear then it used to
the headlights used to be properly aimed level made a good pattern now the highway signs glow alot more then they used to lol
i re installed the springs and bushing like they came out
do the mounts sit lower on the 9bolt housing? do i need a thicker sized bushing for body to spring mount?
its not like i lowered the car 3 inchs or anything just like 1inch to an 1 1/2
i know it dosnt help that i already had alum heads upfront
it just wanst like this with the 10 bolt what did i do wrong?
Old Jul 31, 2013 | 11:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: installed a 9bolt sits lower in the rear
There should be no difference in stance between the 9- and 10-bolt if you reassembled correctly using the same parts.
JamesC
Old Jul 31, 2013 | 12:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Rear springs are indexed too, kif they are eeversed they ca will sit differently. Rotate the 180 and see what happens
Old Jul 31, 2013 | 12:36 PM
JamesC's Avatar
The springs are indexed in the insulator, but I don't believe that will make any difference in how the car sits once they're in place. There is no indication in my shop manual that indexing on the rear is required. At any rate, I've had mine in and out many times without issue.
JamesC
Old Jul 31, 2013 | 06:21 PM
Car: 1991 camaro RS
the car used to sit with rise to the rear now it ie 3 finger gap front wheel to finger 4 finger gap rear wheel to quarter now it sits the same its not super noticeible other then now the lights are aimed high all ive done was the rear axle swap
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sailtexas186548
Aug 26, 2015 03:32 PM
kyleb24
Aug 15, 2015 08:24 AM
