Shock opinion
Old Aug 20, 2013 | 12:31 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Shock opinion
Ok guys my search function isn't functioning. So I need advice on shocks. The car isn't a dd and I want some better preforming shocks. I've recently added subframe connectors and I have Lakewood lcas (freebies) and ill be ordering an adjustable panhard in a couple weeks. Car has eibach sport lines under it and the shocks and struts are next on the list. Just as a weekend warrior and play toy what would be a good shock for handling and the occasional red light launch
Old Aug 20, 2013 | 03:12 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Shock opinion
The name that always gets thrown around is Koni Yellows.
Old Aug 20, 2013 | 03:22 PM
Guest
Guest
Posts: n/a
Re: Shock opinion
KYB AGX is more than enough for a daily driver.
Old Aug 20, 2013 | 03:24 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Shock opinion
Followed by Bilstien.
Old Aug 20, 2013 | 09:01 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: Shock opinion
So the kyb be the way to go then?
Old Aug 21, 2013 | 06:26 AM
Car: 1971 Camaro
Engine: 427
Re: Shock opinion
Buy the best you can afford.
Bilsteins you only have to buy once, when they wear out, send them back for rebuild.
Bilstein and Koni are accepted as the best and are often seen on high end and competition cars.
Kyb are great budget brand. Dint see them on many high end builds though.
Old Aug 25, 2013 | 12:30 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: Shock opinion
besides koni.. what ARE the high end shocks/struts for the thirdgen? if seen some stuff that one might be able to be modded and stuff like the QA1's but other than that?
Old Aug 25, 2013 | 07:44 AM
Car: 1971 Camaro
Engine: 427
Re: Shock opinion
^ besides Koni?
Bilstein.
Old Aug 25, 2013 | 07:50 AM
Alice89's Avatar
Re: Shock opinion
I'm not sure if penske & Afco make double adjustable (With separate reservoir) S&S for our cars, but I think Varishock does. Or at least they used to.
Once you get into Double adjustable S&S it's going to be more and more a track car than a street car. That doesn't mean it's not streetable. However you really do have to spend a good day to day and a half at the track to get them adjusted right for your car.
I see a lot of people on here not adjusting their Koni's (single adjustable) at a track like they should. I can tell you it took me a good 5 hours to get my Koni's adjusted to where they feel best; and they are only single adjustable. I can also tell you those hours were fun and WELL SPENT! After proper adjustment there's definitely a noticeable difference around the corners, on the track and on the street.
By the way; Koni has EXCELLENT Double adjustable S&S; they just don't sell the double adjustable versions for our cars... yet. Try emailing them, they may just pull the trigger and start manufacturing them for us. They do after all make pretty decent sales on Third gens (I know a lot of 3rd gen owners who have Koni's)
Anyways Here's a set of double adjustable rear's from Koni that will install on our cars without modification:
http://www.summitracing.com/parts/ko...maro/year/1998
They are listed for fourth gens but they will interchange on third gens. (Same rear set up)
All they would need to do is build a set of DA front struts and we would all be on our way. For them this would not be hard. Either that or we could use DA koni strut inserts.
Old Aug 26, 2013 | 06:02 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Shock opinion
Viking- rears now... Struts soon.
Double adjustable.
UMI, for one, sells them.
Old Aug 28, 2013 | 12:56 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: Shock opinion
jri will make a set for you if they dont already
Old Sep 6, 2013 | 05:29 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: Shock opinion
you suppose one could adapt a 2010 camaro strut to our cars?
Old Sep 6, 2013 | 07:27 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: Shock opinion
it has been talked about. but there are a few things that will cause an issue... one, is that fact the the weight is diffrent so the valving will need to be changed... two would be the upper and lower mounting points.... the lower one is very close if not the same... the upper one will need to but custom made
Old Sep 6, 2013 | 09:18 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Re: Shock opinion
does the upper need to be extended or shortened?
Old Sep 6, 2013 | 09:37 PM
johndinu's Avatar
Car: '89 GTA 350 hardtop
Re: Shock opinion
I have the prokits and gr2's front and gas-a-just rears. I don't have sfc's for now, but when they'll come and once the gr2's are dead I think I will upgrade to koni yellows.
my findings are that koni yellows at the softest settings are equal to the bilsteins. I love the bilstein hd, but they are not marketed for lowered cars, only heavy duty replacements for stock heigh cars. they only have a rear sport one for lowered cars.
I can definately tell my car needs more dampening in front which the gr2's simply can't provide. $90 gr2's vs $500 kony yellows... I thought I'll just go thru a set of gr2's b4 I'll be able to raise this kind of dough
Old Sep 17, 2013 | 01:12 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: Shock opinion
its how the strut mounts to the body that is the problem, if i remember right, the entire design is difrent, not that it cant be done but its not just a suyple bolt in deal
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
