Camaro vs Firebird springs
Car: '82 Camaro '48 Pontiac Streamliner
Engine: 305ci (SUJ) Holley1850-3
Transmission: TM350
Axle/Gears: Stock
Can I modify Firebird springs which cause my Camaro to ride higher than the rear. I don't want to buy new ones as the taxes and shipping make it uneconomical.
I forgot to compare them when I fitted them.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Camaro vs Firebird springs
You can cut them. Do not modofy them with heat
Transmission: TM350
Axle/Gears: Stock
Thanks. I still have the originals which were broken at the bottom ends. The tester thought it was dangerous. roll eyes
Transmission: TM350
Axle/Gears: Stock
I have seen both 5608 and 5610 advertised for my '82 Z28. There is no air conditioning compressor although the rest is still there.
The vin is IGIAP8775CN156231
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Did you reuse the big rubber spring isolators? You can take those out and use a piece of heater hose or electrical tape and synthetic grease on the top of the spring to bring the rear down a little while keeping some protection against corrosion/ road noise.
Transmission: TM350
Axle/Gears: Stock
The rear is ok. It's the front that I want down but I get the point about the rubber. I did not know about them at the time. I had assumed that both Pontiac and Chevs were the same. Ebay sellers are no help either.
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
