High Speed Handling Questions
Old Sep 19, 2013 | 03:30 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Ok, in a few weeks I will get my car back from the dyno for the final time. Last pull was 780rwhp. Expected pull this time in excess of 850rwhp. I have a 4L80E o/d, 3:25 rear gear and tall "Z' tires. My math says this car will run upwards of 200mph at approx. 7200 rpm and I believe the car has the power to pull it. Can anyone out there contribute solid info from experience, yours or someone else's, how this car may behave at those speeds. I have a 91 Z28, all spoilers and ground effects in place, Harwood forward facing hood scoop but all air is directed into the procharger intake. I have had the car with previous engine to 150+mph and handled decent but did not maintain that speed for any extended period of time for sure. I have also had the car to about 140 with the added hood scoop but at that time, the hood scoop was not sealed to the blower intake so I believe it was creating under hood pressure causing some lift as the car was motor boating a bit at that speed but again, did not maintain speed for very long. The car is a little front heavy with procharger and all the peripherals including big radiator. Who knows something on this.
Old Sep 19, 2013 | 05:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: High Speed Handling Questions
Are you planning to run for extended periods of time at 200mph? You need to consoder building a real front arm dam and splitter at the very least and look into a rear spoiler for the rea for some downforce.
You will find better info on frrax.com on this subject.
Old Sep 19, 2013 | 08:23 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Tell us about your suspension, wheels and tires, aero modifications...
You only need about 500hp to get past 200mph in a 3rd gen, BTW.
Old Oct 2, 2013 | 09:03 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
at 50
Frozer!!!
Jan 19, 2024 04:55 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
