Front Of Car Higher After Sway Bar Install???
Old Sep 28, 2013 | 10:32 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
So i just finished installing a spohn front sway bar, but after i lowered the car i noticed the front is higher what it originally was before the install. Any suggestions?
Old Sep 29, 2013 | 01:25 AM
Rabble's Avatar
Re: Front Of Car Higher After Sway Bar Install???
Move the car around, the suspension needs to settle.
Old Sep 29, 2013 | 02:04 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Make sure you did not put the sway bar upside down
Old Sep 29, 2013 | 12:23 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
+1
The geometry of suspension travel when you lower the car onto the ground means that the tires cannot move upwards because they resist moving outwards along hte arc of a-arm movement. Move the car so the suspension settles in and you'll see a difference. You'll probably even be able to see the wheels stretching out the sidewalls on the outside face of the tire because the tread is holding onto the ground and the a-arms are trying to move outwards and upwards.
Old Sep 30, 2013 | 06:39 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
This is probably only a contributing factor, but it's not uncommon for sway bar bushings to be tight enough to cause bind. When you install new bushings always lube them and check to make sure the sway bar can rotate with minimal effort before installing the end links. If it's too tight a washer under one or both sides of the bushing bracket can loosen them up some.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 12, 2015 06:39 AM
