founders performance suspension
Old Nov 24, 2013 | 01:59 PM
Project-RS's Avatar
Hello, I'm going to place an order on some parts. I'm looking at founders complete rear suspension. It will be a street car, but I want it to handle on a road course also. This car is not stock by any means. I'm looking at double adjustable for everything. Is it really worth it or will the normal non adjustable work just fine? I have umi adjustable torque arm, crossmember, and k member already.
Old Nov 25, 2013 | 12:27 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: founders performance suspension
adjustable is more like set it and forget it. in most cases adjustable is not necessary, you def want the adjustable PHB if your car is lowered, but you can prob just got with fixed lower control arms. also note the double adjustable PHB allows you to adjust on the car which is alot more convient
Old Nov 25, 2013 | 12:30 PM
Project-RS's Avatar
I have 2" lowering springs all around
Old Nov 25, 2013 | 07:56 PM
Project-RS's Avatar
I ordered there on car adjustable panhard bar with poly ends, panhard relocated bar, lower control arms with pivotal bushings, and lower control arm relocation brackets today
Old Nov 28, 2013 | 08:50 PM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Transmission: Automatic
Does Founders offer a discount for board members?
Old Nov 29, 2013 | 03:19 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I went with adjustable for my Panhard since the car will be lowered on weight jacks. For my LCA's I just went with NON adjustable. The only times I see people adjusting LCA's is to center a 28" tire, which I dont plan on running.
Jay
Old Nov 29, 2013 | 12:33 PM
FoundersPerf's Avatar
Former Sponsor
At the prices we sell our parts for we don't have the profit left to offer discounts.
Old Nov 29, 2013 | 01:36 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Can you share what brand rod ends you use in your LCA's?
Old Dec 5, 2013 | 02:04 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
You won't hear complaints from me. I think your price point is perfect for what you get. I love my Founders parts.
Old Dec 6, 2013 | 12:23 AM
Car: 1992 Camaro RS
If you have LCARBs they sometimes dont center perfectly. There's no good reference plane to mount those exactly exactly right. Using adjustable LCA's can help that. Also as the ride height lowers with or without LCA's, the axle will change it's fore/aft position in the wheel well depending on how the LCA is angled. Just depends. Adjustable LCA's will allow you to do a proper four wheel alignment also.
Most people it isnt necessary, but it's nice to have. For me I need them to recenter my axle from side to side as one side is farther forward in the car than the other.
Old Dec 6, 2013 | 12:03 PM
Former Sponsor
We use FK rod ends.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
