Steering Column Swap
Old Dec 6, 2013 | 11:10 AM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Ok, so my tilt bearing went out and all the linkages for ignition and hi beams etc got all screwy. Road Side assistance got me towed into a local repair facility.
So I saw my options as being to either have them rip the column down and replace whatever may need to get taken care of OR to swap the column. I figured the column swap would be easiest route when it came down to the pocketbook. Unfortunately no salvage yards in the Milwaukee area had one available.
My car: 89 Camaro RS, tilt, AT, VATS
Found: 89 Firebird, tilt, AT, no VATS
I figured the only real issue would be taken care of VATS, which is being taken care of via bypassing it. Starts fine.
Problem- apparently this column is a little longer and will not steer. The only thing I could come up with would be the collapsible shaft was extended.
Mechanic will be looking at it this afternoon. Is there anything else that could be a factor besides this?
Suggestions?
If the replacement column cannot be "easily" used, what parts could be swapped over to give me one good column?
My main hold back is $$$, I need to keep this as low cost as possible.
Old Dec 8, 2013 | 11:10 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Steering Column Swap
Is the upper trim collar rubbing the steering wheel? If so, just sand it down
90-92 columns were equipped with airbags and the collar was longer. Using an older wheel on them requires a slight trim or swapping it
Old Dec 10, 2013 | 07:58 AM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Can check with the mechanic on where the problem lies today.
Steering wheel matches this one on eBay.
No sign of airbag.
Old Dec 10, 2013 | 11:40 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I don't know what you mean by "won't steer" ?
82-92 coulmns are all the same length.
I'm guessing that you can't get the intermediate shaft and the column connection fit together ??
The intermediate steering shaft could be extended a bit too far, possibly seized and not allowing it to collapse as far as it should. Use a screwdriver to pry the rubber "boot" covering the joint of the intermeidate shaft and spray some penerating fluid/lubricant in there. Let it sit for a little while and then man-handle the intermediate shaft until it colapses and extends properly; then connect it to the coulmn..... done.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
