Rear LCA and Panhard Bar Delrin Bushings
Old Dec 27, 2013 | 10:16 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I have found the globalwest front LCA del-a-lum bushing kit, and the front Afco kit, but I cannot find delrin bushings for the rear LCA's and panhard bar...
Anyone know where I can find some?
Old Dec 27, 2013 | 10:37 AM
Re: Rear LCA and Panhard Bar Bushings
I doubt it.
Those stamped sheet-rubber parts are so weeeeeenie, that the act of attempting to press the stock bushings out, usually destroys them.
Much better idea to replace them outright with something that you can't bend with your bare hands. Kinda doesn't make sense to put solid bushings into something that itself isn't solid to begin with.
Old Dec 27, 2013 | 10:44 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I have spohn tubular rear LCAs and panhard bar, tq arm, subframes, etc.
The poly crap in them isn't cutting it, I'm tired of greasing it to stop the squeeking and binding. If they dont exist I will make my own LCAs and PHB with some afcos but I'd rather save myself the headache
Old Dec 27, 2013 | 11:05 AM
Re: Rear LCA and Panhard Bar Delrin Bushings
Wouldn't be too tough then, to call up yer local machine shop, and have em make you up something dimensionally appropriate to those other actual metal parts...
Old Dec 30, 2013 | 10:35 PM
lees02ws6's Avatar
The reason no one makes them is that they would completely bind the suspension. Poly has poor multi axis support, as it lacks the pliability of rubber. The del alum bushings you're referring to have absolutely no multi axis support. They do rotation only. You need the twisting motion in the rear lca, as well as rotation. The PHB does also, but to a much lesser degree. Solutions to the problem that offer the same benefit already exist (rotojoints, johnny joints, etc.)
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
