need front sway bar help... what am i missing???
Car: 89 Trans-am
Engine: 305 L03
If anyone could help me out it would be great. This weekend I started putting together the front suspension back together on my trans am. all went well until it came time to bolt the sway bar to the subframe. On the drivers side I only have one threaded hole when there should be 2... What am I missing?I've searched and searched and can't seem to find my answer.... Help
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: need front sway bar help... what am i missing???
Got a pic? Did you pull off two bolts or one? Is it broken or stripped or just gone?
Car: 89 Trans-am
Engine: 305 L03
The car has been apart for a couple years so I don't really remember what hardware came out. I don't think the bolt snapped off when I took it off. in the pic I'm pointing to what looks like should be the 2nd bolt location.
It seems that you are missing the sway bar attaching bracket that I have outlined in black. This is from my V6 3.1L but I visually looked at my '91 305 TBI and it is similar. Also it seems that the previous bolts hole have been (jb) welded in preparation for drill and tapping. Hope this helps. Good luck.
Car: 89 Trans-am
Engine: 305 L03
Does the drivers side look the same? Does it have the same bracket?
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
