another lca question
Old Feb 17, 2014 | 10:30 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I want to replace my panhard bar and lower control arms mostly for the look, I don't drive the car everyday mostly to car shows and just out for a ride. How will the ride be affected I have been reading a lot of mixed reviews, is the driveability affected that much or just when your on it thanks.
Old Feb 17, 2014 | 11:23 AM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: another lca question
There are a lot of opinions on here about the bushings as you've seen. I don't have numbers to back up my results, just seat of the pants experience. On one of my old cars i had the poly/poly Lakewood bars, and the car drove fine. I didn't notice any binding, but I wasn't auto-crossing or road racing, mostly just driving around. On my current car, I have Founders poly/roto-joint lca's and poly/rod-end panhard bar. Before, the car would just burn the tires anytime I hit the throttle hard, now it plants me in the seat and takes off. For what you seem to be looking for, it wouldn't be a bad option.
Old Feb 17, 2014 | 12:16 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks that is the same set up I am looking at
Old Feb 18, 2014 | 06:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Here is a packaged deal that UMI sells. I swapped out my stock stuff for the UMI ones. I have no complaints about the ride or anything after installing them on mine, only compliments.
http://umiperformance.com/catalog/in...roducts_id=140
Old Mar 4, 2014 | 09:08 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
that's the kit I want. how was the ride before and after the install?
Old Mar 4, 2014 | 07:42 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
if i were to change something just for looks it would be something easier to see.just saying.
Old Mar 5, 2014 | 06:54 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The ride wasn't bad before the install. However it did seem to make the back end of the car more stiff and solid after the install.
Old Mar 5, 2014 | 09:46 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Also look at founders. Same fantastic parts...half the price!
Old Mar 9, 2014 | 07:58 PM
KITT1983's Avatar
Got a link?
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
