shocks and struts
Old Feb 17, 2014 | 04:31 PM
skyjack1's Avatar
Car: 1991 Z-28 Camaro
Engine: 350 tpi
shocks and struts
I am looking for a good set of shocks for my 91 z28 350 camaro, Iam looking for a comfortable ride and handling! Would the bilsteins be overkill or what other shock would be a good replacement? thx for the advice..
Old Feb 17, 2014 | 05:51 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: shocks and struts
KYB GR2 Struts and KYB Gas/Adjust Shocks are a set up I and a lot of others have. They are also not Bank Busters like the Bilsteins..
Old Feb 17, 2014 | 06:12 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
What's your budget? Koni yellows are about the best you can buy by most accounts.
Old Feb 18, 2014 | 04:45 PM
skyjack1's Avatar
Engine: 350 tpi
PRICE DOES NOT MATTER . JUST WANT THE BEST RIDE,,,, THX
Old Feb 18, 2014 | 06:29 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I got koni yellows on my 92, but I can't imagine bilstein or KYB being bad for a street car.
Old Feb 18, 2014 | 08:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
If you are just looking for ride quality and not handling then I would go with what DJP87Z28 sayed that is the KYB GR2
Old Feb 19, 2014 | 08:24 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I was looking at the prices between those and the koni's and bilsteins. For the price difference, does it make that big of a difference?
Old Feb 19, 2014 | 09:07 AM
DJP87Z28's Avatar
The only difference is how much you have left in your bank account. The KYB's will work very well on a street car. Unless you want to brag I got Koni's or Bilstein's.
Old Feb 22, 2014 | 03:26 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
Above statement is absolutely not even remotely true. KYB's are not in the same sentence as bilstien or koni. The difference they make in handling & ride quality is well worth the cost difference IMHO. I have had all three before & can tell you from experience koni out handles them all by a large margin and adds quite a bit more control. Probably the bet mod you can do to the car. Bilstiens don't have as much dampening, but really offer a great ride, especially with stock springs. KYB's are not close to either of the other brands. IT is worth it to save/spend the money on the better shocks if you plan on keeping the car. If you just need to fix it, get the KYB's as they are better than blown shocks. BUt the statement above is kinda ignorant..
Old Feb 22, 2014 | 04:04 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I've had all 3 brands you mention in my street cars over the last 20 years and would only suggest KYB for a stock replacement or mild performance (maybe lowering springs) - they don't hve ave the proper valving for serious driving or light track use. I'm referring to the non adjustables.
I have Bilsteins on my Camaro - love them, but they were custom valved to my springs. Not a great ride, but tolerable.
My GTA has Koni Yellows and they are great - the ability to adjust them in minute amounts is worth the time to keep fiddling with them. This applies to ride and also performance, since you can turn the **** to make them softer or firmer anytime you like.
Old Feb 22, 2014 | 06:20 PM
Car: 92 Camaro RS
I have KYB gas a justs on my 69 and they are great comfy shocks but they have nowhere near the performance of the koni yellows I have on my 92 that I autoX and HPDE.
Old Feb 22, 2014 | 06:58 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by paul_huryk
I've had all 3 brands you mention in my street cars over the last 20 years and would only suggest KYB for a stock replacement or mild performance (maybe lowering springs) - they don't hve ave the proper valving for serious driving or light track use. I'm referring to the non adjustables. I have Bilsteins on my Camaro - love them, but they were custom valved to my springs. Not a great ride, but tolerable. My GTA has Koni Yellows and they are great - the ability to adjust them in minute amounts is worth the time to keep fiddling with them. This applies to ride and also performance, since you can turn the **** to make them softer or firmer anytime you like.
What kind of difference are we talking about?
Old Feb 22, 2014 | 08:18 PM
Kennerz's Avatar
From spooky to sportscar type of difference. THe road feel and actual road holding/handling improve with a quality shock absorber. Car will have higher limits along with more control. Major diff in feel/balance.
Old Feb 22, 2014 | 09:44 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Gotcha. I was really thinking about kyb's, that's what my father in law has in his 84. And his rides so much better than mine. But he also has all
The aftermarket suspension goodies along with the kyb's
Old Feb 23, 2014 | 12:13 AM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Monroes and Gabriels are stock replacements- good for a grocery getter or a car you plan on fixing up and selling. The suspension equivalent of an engine tune up.
KYB's and Tokicos are an upgrade much like adding an aftermarket air filter is-very little difference over stock if any, most is probably all in your head
Bilsteins and Konis are like adding headers- measurable difference as well as a significant improvement easily detected by the butt dyno.
If you want a nice, good riding and handling car that you plan on keeping for a while, Konis or properly valved Bilsteins are it. If you just want your old truck or grocery getter to be slightly kinder to your kidneys or you want to be able to say that the car you're selling has new shocks, OE replacement are the way to go. I wouldn't bother with the in between stuff, unless it was on special and you know you won't regret it and want to upgrade a few months later.
If you care enough to ask us for advice, instead of the counter guy for whatever's on special at O'Napazone, you probably already know the answer
Old Feb 23, 2014 | 09:07 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by midnightfirews6
Monroes and Gabriels are stock replacements- good for a grocery getter or a car you plan on fixing up and selling. The suspension equivalent of an engine tune up. KYB's and Tokicos are an upgrade much like adding an aftermarket air filter is-very little difference over stock if any, most is probably all in your head Bilsteins and Konis are like adding headers- measurable difference as well as a significant improvement easily detected by the butt dyno. If you want a nice, good riding and handling car that you plan on keeping for a while, Konis or properly valved Bilsteins are it. If you just want your old truck or grocery getter to be slightly kinder to your kidneys or you want to be able to say that the car you're selling has new shocks, OE replacement are the way to go. I wouldn't bother with the in between stuff, unless it was on special and you know you won't regret it and want to upgrade a few months later. If you care enough to ask us for advice, instead of the counter guy for whatever's on special at O'Napazone, you probably already know the answer
Koni yellows are definitely at the top of my list!
Old Feb 23, 2014 | 05:31 PM
Alice89's Avatar
It will be a good idea. Even hated Honda owners know what a good set of S&S will do for your body control. Google some reviews on both Koni's & Bilsteins. Almost everyone from domestics/import to even exotics aprove of both Koni's & Bilsteins for street use. They can also be used on the track with great success.
Good luck with your build.
Old Feb 23, 2014 | 07:01 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I have KYB and they are fine as a stock replacement /cruising shock
Koni Yellow will go in next as my wife drives my IROC and she needs all the help she can get
Old Feb 26, 2014 | 10:26 PM
ws6transam's Avatar
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
For what it's worth, I bought my Koni's in 1990, and they STILL work fine after all these years. They were the very first mod I made. If you are going to be a long term owner or use it at the autocross track, they are probably worth the money.
Old Feb 27, 2014 | 08:42 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Wow! Thats a long time
Old Feb 27, 2014 | 09:19 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
It's been a while, I think my back shocks are Bilsteins or Gabriel....can't remember, just remember they are gas shocks, same with the front. Great performance, these cars handled pretty fantastic in stock form too.
All depends on what you want to do. AutoX, sure, spend a little more money. Dragging, who cares how it takes a turn. Cruising, totally up to you (technically all the other ones are too but yeah)
Old Mar 19, 2014 | 10:03 PM
I'llrocya's Avatar
Car: 1984 Camaro Z28 H.O.
Engine: 5.0. L69
Transmission: Automatic
Axle/Gears: 9 bolt disc 3.27 Posi
I have monroe sensa trac, I bought them last year. They're not the most expensive nor are they the cheapest. I needed shocks so I decided to give them a try, Compared to my old shocks it's like night and day, my old shocks were not blown I'm just upgrading my suspension. It's not like I have anything else to compare them to but I do like them. It still rides like an 80's Camaro but because of other upgrades from Spohn it handles very well.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
