9 inch sway bar links.
Old 04-27-2014, 08:05 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
anybody know if the sway bar links in the spohn kit for 9 inch rears are the same length as stock or if the kit from hawks will work. broke a link and lost a bushing so I was thinking about just getting the whole kit from them.
Old 04-28-2014, 11:17 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: 9 inch sway bar links.
I run NAPA premium stock end links on my 9 inch axle if that helps. No waiting on shipping is an added bonus
Old 04-28-2014, 08:13 PM
ziggy89's Avatar
Engine: 383
what do you use to mount the sway bar to the axel?
Old 04-29-2014, 05:18 AM
406TPI's Avatar
Car: 1985 IROC-Z
My 9" came with the mounts already.
Old 04-30-2014, 09:12 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Stock length end links here. Spohn's might be a hair longer since I think the mounts space the bar a little lower on the axle tubes than stock.
RS Reaper
09-27-2015 07:04 PM
raymondandretti
09-27-2015 06:43 PM
monte87cortez
09-26-2015 08:10 PM
JSDaddy189
09-26-2015 03:50 PM
dbrochard
Wheels and Tires
09-25-2015 05:40 PM
Quick Reply: 9 inch sway bar links.
