SFCs= less grip?
Old May 7, 2014 | 11:16 PM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
SFCs= less grip?
Recently got some UMI sfc's, and spohn lcas installed. The car seems much more solid, but I can kick out the rear end much more easily now.
Installed a wonderbar and strut tower brace (myself) and the car is MUCH more solid! It seems that all the supports are working together now and it's much better than SFCs alone.
BUT, now it also seems like it's much harder to maintain traction under fairly, well, pedestrian conditions. It seems like the car just always wants to break loose, so to speak.
Do I just need more tire (my first thought) or is something not right here? It seems like these "upgrades" have reduced low/mid speed cornering in favor of high speed.
Some car info:
92 camaro rs, torsen rear, motive cromo axles
225/45r16s
KYB gr2s x4 (2yrs old)
Camber -1 right, -.8 left; stock caster
Poly sway bar mounts (all), 34mm front bar
Any help is welcome! Help me get more grip!!
Old May 8, 2014 | 02:31 AM
Alice89's Avatar
Re: SFCs= less grip?
Rear sway bar is probably too big. You will need track testing to re-balance the car to your tastes (alignment/swaybars/springs/S&S rebound).
Old May 8, 2014 | 07:11 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I think you just need better tires.
When you tighten up a car that has major flex issues (like every third gen) then you are eliminating an energy loss by allowing more energy to be transferred to the wheels instead of out through the body via flexing/etc.
Old May 8, 2014 | 10:58 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That's where my mind went when I read your description.
Old May 8, 2014 | 11:14 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The point by NOSHO is everything works together. Change one thing and it's likely something else needs to change to work best with the first change. I always knew suspension set up wasn't a simple thing but the more I've read the more complex it seems to get!
Old May 8, 2014 | 01:18 PM
SlickTrackGod's Avatar
On Probation
Has nothing to do with tires being better or worse on a chassis change.
The chasis is now stiffer so the inside rear wheel lifts easier where before the chassis flex kept it more planted.
You can search on here where I have stated a dozen times over the years that sfc addition requires a minimum 2mm drop in rear sway bar size.
The addition of sfc's will result in more consistent tire footprints in relation to each other.
Old May 8, 2014 | 01:27 PM
Alice89's Avatar
This is exactly what I was thinking when the op described that he could "kick out the rear end much more easily now" after installing chassis bracing.
Old May 9, 2014 | 11:59 AM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Less rear sway bar makes a lot of sense. I do plan on larger tires in the future, but for now I guess it's time to look for a smaller bar!
Old May 9, 2014 | 12:07 PM
On Probation
Nope. Buy the Jegs panhard relocation bracket and drop the panhard mount on the axle side one hole from stock position. Trust me you'll thank me later. They are about $80
Old May 9, 2014 | 08:45 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You still only want the panhard bar to be parallel with the ground/horizontal correct?
Old May 9, 2014 | 08:59 PM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
SlickTrackGod: is this significantly easier than getting a smaller swaybar? More effective? Or is it because I'll be able to change it later?
I understand why it would work (roll center will drop) but I'm just trying to be practical.
Old May 9, 2014 | 10:15 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Mmmmmmmmm, good discussion. I had Alstons put on last year in the middle of the autocross season and immediately noticed that the car wasn't snap loose nearly as bad. It still pushes some but doesn't immediately transition to snap loose anymore. Buuuut, I did notice that the rear axle felt like it wanted to go to the right on launches. I don't remember it doing that too bad back in my drag days. Granted these autocross courses aren't prepped like a strip.
These days a lot more autocrosses in my area take place on speedways where you start on the banking. Whether they start us counterclockwise or clockwise it always wants to go to the right on launch. I thought it was just us pushing the car harder and that I needed to replace the floppy stock panhard rod but this relocation bracket sounds like the hot ticket. Perhaps people with this issue should do both? Also the inside rear wheel lifts fairly often (not high, but enough to make the tire spin) especially in right turns both at autocross and coming out of 13 at Nelson Ledges. Diffs don't like it! I have an 87 IROC so the stock rear bar is fairly big.
Old May 10, 2014 | 05:29 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Weaksauce, do you have LCA relocation brackets??
Old May 11, 2014 | 05:10 AM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Flip, I do not. The car is not lowered and it won't be in the foreseeable future, so it's not something I was looking into.
Old May 11, 2014 | 05:58 PM
Flip 2's Avatar
Engine: C5 LS1
The sticky says, even if it's not lowered, trailing arms in the stock location can have an unfavorable angle. They would probably do a lot to cure your tire spinning. Plus, even it's ok sitting still, as soon as you put any roll into it, the outside trailing arm goes in the wrong direction for traction. Add some squat from acceleration……..
Of course, too steep an angle makes braking an exciting proposition. This is very true- I tried the lower setting once. It hooked up like mad, but the car got very funny as soon as you let off the gas and turned the steering wheel- like for bend in the road. 1 test drive and I put it right back. LOL.
Another thing to think about is setting your pinion angle.
BTW- I just went to a second set of SFC's (Alston- the inners) and it stiffened my car a ton. Had no bad effect on my traction, that I have seen.
Old May 12, 2014 | 11:28 PM
Flip 2's Avatar
Engine: C5 LS1
Dean-
Not coming up with this item on Jeg's website……
Assume you are suggesting lowering the rear roll center.
Old May 12, 2014 | 11:33 PM
Flip 2's Avatar
Engine: C5 LS1
UMI relocation brackets have the holes to choose from, instead of the two offered on my Spohn's.
The upper of the 3 holes is probably best for cars that are not lowered.
Old May 13, 2014 | 08:39 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Originally Posted by Flip 2
Dean-
http://www.jegs.com/i/Jegster/550/41...oductId=754011
Old May 13, 2014 | 09:01 AM
Flip 2's Avatar
Engine: C5 LS1
Thanks-
Old May 19, 2014 | 09:02 AM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Thank you all for the help! As soon as I get some good time off I'll be trying some of your ideas.
I may opt for the lca relocator and panhard relocator over the smaller swaybar. I like to tweak settings wherever I find them, so these two options really speak to me!
I'll keep you posted...
Old May 20, 2014 | 10:09 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
225/45r16s Any help is welcome! Help me get more grip!!
I would like to add that by not running the stock 245/50R16's you are leaving some grip on the table. What the others have suggested is the fix to your problem. This is just one more thing that will help.
Or you could move up to 17x9 or 18x9 with some 275's but thats another thread.
Old May 21, 2014 | 11:51 AM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Yeah 17x9s are in my plans but I want to wear out these skinny ones first!
Old May 21, 2014 | 01:42 PM
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
I'd also like to know the answer to this question.
Old May 21, 2014 | 02:11 PM
Flip 2's Avatar
Engine: C5 LS1
The answer is yes.
Old May 21, 2014 | 02:21 PM
Zeifer's Avatar
Engine: 408 LSx
The answer is yes.
Much appreciated. Added PHBRB to my list of stuff.
Old May 21, 2014 | 08:14 PM
On Probation
Sorry, I missed this.
You can have the chassis side bolt about 1" higher from the ground then the axle side bolt when both measured at static heght without anyone in the car and aprox half tank of fuel. Dynamic set and bump travel articulation will put it past parallel the opposite way. It's a happy medium in travel. If you set the oanhard parallel at static, it will very likely severely invert in corner set & bump travel combined.
Old May 21, 2014 | 09:00 PM
Flip 2's Avatar
Engine: C5 LS1
Ah, better!
Old May 22, 2014 | 07:20 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
when i added sub frame connectors i had done a strut brace and wonder bar, instant improvement to the rigidity of the car, i added a 12 bolt rear axle and with 36/24mm sway bar combo it was a nightmare the rear was so loose, i since removed the 24mm for an 18mm and it's much more easier to control
Old May 22, 2014 | 09:01 AM
Joe Tag's Avatar
Disregard what was here, guess I'm just
Old May 22, 2014 | 02:41 PM
conlinj's Avatar
I too also had a lack of "grip" after putting in spohn lca's The problem is the poly mounts, they are too stiff to let the axle rotate in relation to the car when it leans. The poly's are great for straight line traction and wear, but they do not allow rotation like the soft rubber mounts or rod end lca's do.
Old May 22, 2014 | 02:54 PM
Zeifer's Avatar
Engine: 408 LSx
This is the exact reason why when I get my LCAs I'm going to be doing Founder's poly/rod-end on-car adjustable LCAs. Bind/snap = bad news bears. Poly is fine for the panhard bar, but LCAs are subject to much more torsion due to body flex.
Old May 22, 2014 | 03:24 PM
conlinj's Avatar
A friend has those founders pieces, softest poly I ever felt. Definitely a step in the right direction. I mull over the derlin rotojoint/delsphere or full rod ends. My car isn't a daily driver anymore so I'm leaning towards the rod ends more.
Old May 22, 2014 | 08:12 PM
Zeifer's Avatar
Engine: 408 LSx
Founders has ones with poly on one end and the rod end on the other. Should be a good balance.
Old May 22, 2014 | 11:44 PM
On Probation
Poly on the chassis side is fine, but yes putting poly on the axle side will lock up some of the articulation of the axle. If the mounts where twice as wide you probably would not need a panhard rod either.
JoeTag- I do not recall the avatar you are talking about. Nothing of that sorts comes to mind.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
ctoledo0834
Sep 18, 2015 04:16 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
luvofjah
Sep 10, 2015 10:41 AM
