rear sway bar?
Old Jul 25, 2014 | 02:24 PM
quik88's Avatar
Engine: 406 sbc, dart iron ea
rear sway bar?
i am looking for a rear sway bar for my drag car. i have the stock one that came in a 88 rs. my question for you guys is how big is a 2000 b4c camaro? i found a local guy selling one on craigslist,
Old Jul 25, 2014 | 03:01 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: rear sway bar?
Why is a sway bar needed for drag racing? I can see for cornering. Is it torque induced body roll or something?
Old Jul 25, 2014 | 03:24 PM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Re: rear sway bar?
Yes but drag roll bars are very different from normal bars, usually much stiffer. And to answer the OP's question the 4th gen rear bars are 19 or 21mm so smaller than our 3rd gen's bars
Old Jul 25, 2014 | 05:07 PM
quik88's Avatar
Re: rear sway bar?
thanks for the response man.
Old Jul 28, 2014 | 07:27 AM
UMI Sales's Avatar
Re: rear sway bar?
Here is a drag anti-roll bar for your viewing enjoyment.
http://umiperformance.com/catalog/in...roducts_id=325
Huge rates keep the car nice and level instead of lifting the LF tire (or twisting plus lifting both).
ramey
Old Aug 7, 2014 | 08:54 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: rear sway bar?
You probably have the 18mm, stock bars go as large as 25, but the 23 is much more common than anything else larger than 18, as far as I can tell. Forget the ads, go visit the salvage yards. Shouldn't be over $20. Take some 13 mm wrenches and some penetrating oil.
Old Aug 7, 2014 | 06:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: rear sway bar?
After I back halved the car with a 4-link, the body roll was really bad when I launched. It felt like the car wanted to change lanes. Installing an anti roll bar now pulls both front wheels evenly and I can just about let go of the steering wheel when I launch now.
I doubt an OEM bar would be as nice but something is better than nothing. Poly bushings are better than the soft rubber ones but rod ends are even better.
Here's a good race version designed specifically for third gens. It's very similar to a universal kit I bought off ebay. With the 4-link, I needed something that I could modify and work for my setup.
http://www.racecraft.com/index.php?m...de639f1138f53d
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
