Are these kits worth it?
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
I am almost done restoring my interior, and suspension is next. Car hasn't ran since at least 2006, and hasn't been inspected since around 2004. I am sure the stock suspension is a night mare.
1. What are the MUST replacements for when a car has been sitting.
2. What are the recommended replacements
3. Are these kits worth it? http://www.ebay.com/itm/291158216462?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Car: 1983 Z28
Engine: 385 Fastburn
Re: Are these kits worth it?
1. Anything that is dry-rotted. Check all bushings and rubber parts.
2. Poly bushings across the board.
3. Possibly if for no other reason than it gives you what you need in a nice package all at once. However, if you can crawl under the car and check- If any of the parts above will still hold grease and don't seem to be extremely loose/worn out then you can hold off. However, if money is no object, and you have no records of any of it every being replaced before, then sure, have at it and get the kit.
Car: '87 Trans Am
Engine: 5.0L-V8
I wouldn't say moneys not an object, I am just taking my build slow. Not sure if you seen the build thread I started:
LINK
I just want to do it right the FIRST time, especially if it will be easier before installing motor and paint, etc. Especially also since I got my hands on a new rear end and if I am pulling that out, meswell replace some other stuff while its out right? Which brings me to another question, if you'd pull the read out of your car, what would you check and replace, same as front?
Also, bushing.. will this kit take care of everything? http://www.ebay.com/itm/ENERGY-HYPER-FLEX-MASTER-BUSHING-KIT-82-92-CAMARO-/190717133756?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AFirebird&hash=item2c67a083bc&vxp=mtr
LINK
Car: '87 Trans Am
Engine: 5.0L-V8
Also, does anyone have a non-eBay kit? lol if you can't tell I like things wrapped up and simple.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Summit, 1ATony and no doubt others have kits but none I've seen at this price. Seems really cheap so maybe the parts really cheap. Or you can source the just the parts you really need individually. Depends on what you'll do with the car and if you want stock or uprated suspension and feel.
Car: '87 Trans Am
Engine: 5.0L-V8
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
put a similar style "1-click-kit" on a 2000 blazer last year, i just replaced it again with MOOG parts. they are cheapos
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
The "kits" do not come with engine mounts, tranny mounts, torque arm mounts or sway bar bushings (they come with end links bushings)...
Since there were 2 Torque arm bushings used, and many different size sway bar bushings....
I did A LOT to my car... Alston's and Spohn SFC's, Bilstein all around, new Moog Springs, Poly everything, Del Lum A Arm bushings, Jamex Strut Tower Brace, Wonder Bar, Founders 3 way LCA's and Panhard bar, just got my rear end redone & Spohn torque arm...
I am utterly amazed at how nice / smooth and in control my firebird rides....
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The kit is made by midwest, I do not know anything about that manufacturer though that might not be saying much. My advice would be to purchase all MOOG parts through a local parts store that will keep a warranty on file. That way if they need replacing due to wearing out, abuse, bad installation, misuse or whatever it is a no questions asked swap. Also the tie rod connectors/adjusters you show are the weak stamped steel versions--pass on those and get the beefy version that look like really long nuts.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
It's good to replace all the steering linkage, balljoints, struts and mounts at the same time. I get a lot of piece of mind from replacing everything in my front end with new, quality parts. Also by replacing it all at once you won't be replacing it one part at a time as it all wears out.
I used Moog steering and ball joints, GC weight jack springs,koni struts, J&M product strut mounts, GW del-a-lum bushings, timken wheel bearings, QA1 tie rod sleeves, Energy suspension sway bar bushings and links, and added a TDS wonder bar. Of course you don't have to go to the extreme I did like the GC weight jacks or GW del-a-lum bushings, I just wanted to give you a list of parts and give you an example of a quality build. It was well worth it. I love the way it drives every day and handles on the race track without concern of any old parts breaking because it's all NEW!!!
Car: '87 Trans Am
Engine: 5.0L-V8
Ok, what about these bushing kits, seems to have a lot more than other one I posted:
http://www.ebay.com/itm/Prothane-7-2008-82-92-Camaro-Firebird-Trans-Am-Total-Suspension-Bushing-Kit-/380618789438?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=53redIcCwcdRJP153rUlsLBGmB0%253D&orig_cvip=true&rt=nc
Also, What about this wonder bar:
http://www.ebay.com/itm/271537627908?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Car: '87 Trans Am
Engine: 5.0L-V8
That prothane kit seems to have a lot of sway bar bushings which would cover the various sizes... it shows 4 sway bar end links, though it only list the front... and it seems to have 2 different torque arm bushings, looks like they are 2 piece... only thing missing is motor mount...
Do a search on Spohn wonder bar, some have had problems with it...
There are factory ones and other brands...
Car: 1983 Z28
Top down solutions sells refurbished factory wonder bars AND there own "suped up" version for cheaper than any other providers. Alot of your after market wonder bars are oversized and overpriced. If you look into what they are meant to do you can see that a giant one isn't necessary and the factory piece will provide more than adequate bracing.
That Spohn bar though, it looks to be about the same size as the one that TDS makes.
I've never heard of prothane, they look similar to Energy Suspension though.
Car: 1983 Z28
I understand the want to "do it right the first time" too btw, and I believe suspension is definitely an area that it is important to pay attention to the details. I would probably do the same thing if in your position.
Car: '87 Trans Am
Engine: 5.0L-V8
Thanks guys, all the information is appreciated. I am close to getting my interior back in, and when that happens it's all suspension next.
Any other input is also appreciated.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
