front spring help needed( engine swap)
Old Aug 24, 2014 | 11:59 AM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
my car started life as a 2.8 car with no options other than a.c, but the motor was blown and I did a carbed v8 swap with no a.c or emissions stuff not even cats. with that being said i never changed the front springs or sway bars. recently i found i havd a broken spring so i thought time for a front suspension work. i bought a 34mm suspension techniques sway bar and new moog struts for a v8 car and moog coil springs for a 305 car. i know the springs are indexed correctly and it drives straight down the road and no more floating in the front like a boat but the fender gap is huge! it looks like the front has more gap than the rear. the rear suspension is all for a v8 car as well with a bigger sway bar. did i buy the wrong springs or something? should i have bought v6 springs again? i really don't like the gap.
Old Aug 24, 2014 | 06:34 PM
JJ88GTA's Avatar
Car: 1987 GTA, 91 1LE TA
Engine: 5.7L
Re: front spring help needed( engine swap)
Assuming* the springs are indeed the correct rate(sometimes aftermarket springs aren't) check again that they are installed correctly. Never hurts to triple check! I'm personally not sure if any of the suspension parts differ from 6/8.
I have noticed moog springs on other vehicles do something similar but generally settle in. If you are still not happy with them though, remove them while they are still 'new' and you shouldn't have a problem returning them due to incorrect ride height.
Old Aug 24, 2014 | 07:48 PM
deadman's Avatar
Car: 89 camaro
I would assume a difference between 6 and 8 because of the weight difference.
Old Aug 24, 2014 | 09:10 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
How old are the rear springs? They could be old and sagging compared to the new, fresh front springs.
Old Aug 25, 2014 | 06:45 PM
deadman's Avatar
Car: 89 camaro
rears are about 1 month older than the fronts.
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
IROCZ1989
Jan 24, 2016 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
