Sway Bars
Old Oct 12, 2014 | 01:16 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Sway Bars
I have a 91 RS Convertible that I have went through completly. It would take to long to tell you everything I have done. Lets say I have $6,500 into the suspension alone. The only thing I haven't changed are the sway bars.
The front one is 33mm I think and the rear is 24mm. I did put new bushings and ends just not bars. Here's my question...
Should I spend the cash and put aftermarket bars on or would it just be spending money that does'nt need to be spent?
Old Oct 12, 2014 | 10:18 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Sway Bars
First, I doubt your car has 33mm front and 24mm rear. If it is like my 90 RS convertible it has 30mm front solid sway bar and 21mm rear. I swapped a 34mm hollow front sway bar and matching 23mm rear bar. I also installed a steering brace (aka wonderbar). The 34mm hollow front sway bar AND the steering brace weighs less than the lower performance 30mm solid bar they replaced.
IMO this is the most obvious case of a win-win you could get. A performance gain along with a simultaneous weight reduction is hard to replicate elsewhere.
You can further upgrace the cornering ability by upgrading to a 36mm hollow front sway bar and matching 24mm rear sway bar, but you will also pay a weight penalty for this performance gain.
Lon
Old Oct 13, 2014 | 09:45 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Re: Sway Bars
Stiffness gained by adding Wonderbar and replacing factory sway bar are worth the money. As I remember, the Wonderbar has six bolts; "what could go wrong?" [Don't ask]
Old Oct 14, 2014 | 02:31 PM
gregl316's Avatar
Re: Sway Bars
Thanks James. I have a wonder bar allready. I do have a 33mm front sway bar too give or take a mm.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
