caster camber plate "spacers"
Car: 92 Z28
Engine: Boosted LSX
Re: caster camber plate "spacers"
I dont think mine is 1inch. but are you talking like this?
http://www.cecoatings.com/images/Car...-51-19_497.jpg
http://www.cecoatings.com/images/Car...-09-39_543.jpg
Engine: 4++,350 & 305 CIs
A lot of guys used to make them but they were prototype stuff.
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Materials and the machine time cost is the biggest problem. I'm currently working on a set made out of Delron. Since there is only compression load it should be just fine, not to mention much lighter than a 1" thick piece of aluminum.
I'm currently waiting to hear back from my design group on the cost to produce these.
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
I am interested on spacers!!!!
As in Yesterday.
Dennis
As in Yesterday.
Dennis
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I have some 11/16" T6 aluminum spacers that I had made for a coil over setup. I had 2 sets made. the look like the above version but at 11/16" tall. They allow almost 3/4" spacing. I currently put on a set of 1/2" spacers for mine. and this is what they look like.
I can sell a set of the 11/16" ones if someone wanted them. they are threaded for 5/16-18 bolts.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Car: 87 RS Camaro
Engine: LS6
the struts are trying to push sideways towards the engine as the car sits, and they get pushed in every direction as the car drives down the road and hits bumps and takes corners and what not... i wouldn't be trusting any form of plastic to hold under those kinds of loads..
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You guys see any benefit ride quality with spacer and aftermarket camber plates
morrow
Jan 13, 2024 12:29 PM
monte87cortez
Sep 26, 2015 08:10 PM
