quick question on rear sway bar clamps
Old Feb 26, 2015 | 08:09 AM
tb3's Avatar
tb3
Car: 1989 Firebird Base
Engine: 2.8 V6
Axle/Gears: stock
I'm removing the skinny rear sway bar on my base firebird and installing the 24mm bar.
I have new poly bushings and bushing brackets, but my kit didn't come with the U-clamps and brackets that clamp onto the rear-end.
The old ones on the car now are in excellent shape, and I can blast/prime/paint them and re-install, but since this is a 89 base Firebird, I was wondering if the larger rear sway bar firebirds came with beefier U-clamps/brackets.
Should I re-use what I have? or is there better ones I should use?
thanks!
Old Feb 26, 2015 | 09:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: quick question on rear sway bar clamps
thanks!
The bushing are different sizes, but the U's are all the same. I'd reuse.
JamesC
Old Feb 26, 2015 | 09:35 AM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Old Feb 26, 2015 | 10:03 AM
tb3's Avatar
tb3
Engine: 2.8 V6
Axle/Gears: stock
thanks guys!
that's what I needed to know.
I will re-use
Old Feb 26, 2015 | 11:11 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
For future reference, the rear sway bar bushing kit I sell comes with the u-bolts, saddles and bushing clamps. I also have the option of getting JUST the brackets, U-bolts & saddles if (as in the OP's case) you did not get them with the bushings you ordered. When I switched suppliers from Gulsdtrand to Energy Suspension my rear bushings now use the ES aftermarket brackets along with their bushings. If you need the GM rear sway bar brackets I still have plenty and can supply them instead if you need them.
Lon Salgren
Old Feb 27, 2015 | 01:24 PM
tb3's Avatar
tb3
Engine: 2.8 V6
Axle/Gears: stock
Lon Salgren
thanks! I am going to go ahead and re-use mine, but I guess I should've ordered from you.
I ordered mine from hawks third gen and they didn't come with them.
Old Mar 4, 2015 | 06:31 PM
lonsal's Avatar
When comparing price it is also important to compare what you are getting for that price. Mine include the saddles, u-bolts, new nuts & washers in addition to what you get from other sites. As I mentioned before I have included options to delete the brackets, to delete the bushings, etc. also.
Lon
Old Mar 5, 2015 | 09:03 AM
tb3's Avatar
tb3
Engine: 2.8 V6
Axle/Gears: stock
Lon
Good to know! I will definetly hit you up next time I'm needing suspension parts.
Do you have a link to your site?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
happyhapka
Aug 15, 2015 04:42 PM
z28addict8490
Aug 7, 2015 08:48 PM
