What rear suspension first?
Old Mar 8, 2015 | 11:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey all,
84 T/A
Car is lowered 1.5" on Hotchkiss lowering springs and has hotchkiss sway bars and poly bushings already done. Wow, 7 years ago now..amazing how the time flies). There is more done to it, but that's it for suspension in the rear. More info can be found on my link in my signature on the whole car.
I've got enough money to do wither LCA's and founder relocation brackets or an adjustable panhard bar. Not enough to do both. Where should I start? Any advice is greatly appreciated.
Old Mar 9, 2015 | 12:45 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: What rear suspension first?
LCA-
Old Mar 9, 2015 | 12:53 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Well if its lowered I'd say get the lcarb and if you get the brackets might as well do the LCA while your there . I'd say torq arm next.
Old Mar 9, 2015 | 09:38 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Looks like it's LCARB's and LCA's. Why the Torque arm before the Panhard?
Old Mar 9, 2015 | 01:03 PM
ziggy89's Avatar
Engine: 383
torque arm will help with wheel hop and takes the stress off the transmission if you do it like I did with a crossmember mounted torque arm and ive been told it helps with acceleration coming out of corners. honestly the only reason I even did a phb was for adjusting the axel side to side because I went aftermarket rear and I did all three at the same time.
Old Mar 9, 2015 | 02:57 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I was looking at that, I just don't have the $400 right not for that set up. It's on my "to do list" however. I was just wondering where to start and looks like LCA's and LCARBS are the way to go.
Old Mar 9, 2015 | 07:15 PM
SlickTrackGod's Avatar
On Probation
I see it's time to preach to all the new members on here give bad advice.
Did anyone care to look at his car pictures or read his SIG? Nope.
#1 on any car ....TIRES. Why? The are your connection to the ground. They always need to be in good shape for the car to roll safely.
#2 for the love of god, SHOCKS people. Shocks ate your most primary suspension function to keep the tires in contact with the ground...AND...they control the chassis weight for safety and control.
Lca's, relocation brackets, sfcs, sway bars, tq arm, panhard, etc... Are all crap to a car that does not have the basic #1 and #2 in line of importance.
Old Mar 9, 2015 | 08:25 PM
Ozz1967's Avatar
Car: 1984 Trans Am
LOL...
1. Cooper Cobra GT's with less than 1000 miles on them.
2. 13 year old Monroe Sensatracs' that do leak just a little and probably need replacing. However, I want Koni's but they're out of my price range at the moment and I don't know where I can get a full set of shocks/struts for $300 or less unless I go back to the Sensatracs
So I was looking to get some insight on what to get next.
Old Mar 9, 2015 | 08:33 PM
Car: 88 IROC-Z
Truth
Old Mar 9, 2015 | 10:42 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
If your car is lowered, how did you keep the axle centered with the stock panhard rod?
Old Mar 9, 2015 | 11:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I haven't touched it, hasn't caused any issues that I've noticed.
Old Mar 10, 2015 | 12:06 AM
The LCARBs are good for eliminating wheel hop. If it were me, I'd get some good shocks and the adjustable panhard rod, but then again I don't even have a panhard rod anymore.
Old Mar 10, 2015 | 12:28 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I could probably afford to do rear Koni's but nothing else right now. No way can i afford the $460+ for tje fronts alone. Maybe this tax return plus next year's lol. And I Have to limit myself as i prep for a possible move later this summer.
Old Mar 10, 2015 | 05:10 AM
ziggy89's Avatar
Engine: 383
hmm you make a valid point I had never thought about that. never crossed my mind. maybe a phb would be a good idea.
Old Mar 10, 2015 | 12:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Save your money and do shocks and struts. The other parts will not benefit you at this time and depending on bushing material, may actually hurt you.
Keep an eye on the classifieds, you can usually save money on almost new parts there.
Old Mar 10, 2015 | 12:52 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yeah, looks like this might be the best solution now that I look at it.
Damn Shocks/struts are almost as much as a new set of tires. hehe
Old Mar 10, 2015 | 10:02 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Originally Posted by Ozz1967
LOL...
I would without a doubt say buy the rear Koni shocks and nothing else at the moment. They are worth the money. Once you get them put in you'll see a world of difference between the front of the car and the rear of the car. Down the road, maybe 6-8 months from now, you can do the front Koni struts. They're the expensive part.
LCA, PHB, relocation brackets, that stuff can wait for way down the road.
I would put it like this. Konis are like putting insulation in a house in Alaska that doesn't have any insulation. The other stuff is like putting curtains over your windows.
I've done a lot of suspension stuff over the years. But nothing has made as much difference as the shocks and struts.
Old Mar 10, 2015 | 11:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
That sold me. Thanks!
Old Mar 11, 2015 | 12:06 AM
On Probation
Very well put "Flash"...(lol- A little inside joke)
customblackbird
Aug 15, 2021 10:16 PM
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
