EBay purchase KYB Excel-G strut issues
Old Jul 2, 2015 | 01:00 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
I purchased my KYB Excel-G struts part number 236001. I received them today and got part number EX236001 and there labeled EX-2 not GR-2. I contacted KYB and they indicated I was not there part number. So the question is did I buy knock-off struts or just Old stock that KYB didn't have in there system. I did some googling and could not find any info.
Old Jul 2, 2015 | 04:16 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: EBay purchase KYB Excel-G strut issues
what is the part number on the actual part. sometimes vendors put their out numbers on the outside of the box for their own records
Old Jul 3, 2015 | 11:49 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
was the price significantly lower than what you'd pay at places like Summit?
then they are likely knockoffs, and you should have known that when you ordered them because if something seems too cheap for what it is, then it's probably not the thing you thought you were ordering.
Old Mar 23, 2016 | 02:48 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Did you ever get this figured out. I ordered a set and they arrived today but as EX-2, Not GR-2, as well. Listed showed and listed them as GR-2's with the KYB part #.
I did just find the the EX236001 part # listed on streetperformance.com website listed as KYB Excel-G, which I believe was the predessor to the GR-2. Box looks like a KYB box so maybe old stock someone bought/had?
http://www.streetperformance.com/par...-ex234019.html
Old Mar 23, 2016 | 02:51 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
No, I didn't pretty sure they are knock-off's. The place I ordered them would return them either. lesson learned.
Old Mar 23, 2016 | 03:04 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Did you use them?
Old Mar 23, 2016 | 03:06 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
nope they are sitting in the closet. I ended up putting QA1 coil-over's all the way around. But I just bought a GTA and I plan on using them on it.
Old Mar 23, 2016 | 03:53 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
It is common for retailers/distributors to "create" their own part numbers by adding letters to the manufacturers part numbers to help further define the product. This is done to prevent the occurrence of two different parts (from two different manufacturers) having the same part number in a particular reseller/distributor's computer system, which would cause lots of confusion.
In this particular case, KYB's part number for the front struts on our cars is 236001. Summit, for example, lists the part number as KYB-236001. They are the same part but have different part numbers because of the different sellers.
Excel-G and GR2 are one and the same. There's absolutely no difference between them except for the color of the coating on the housing. KYB made the decision to make the GR2 series of shocks/struts look more like factory replacements so they changed the shock/strut housing to black and relaunched the product under a new name (Excel-G).
Old Apr 3, 2016 | 09:08 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
I'm finding the Excel-G's all over ebay, Amazon, Summit, etc now. These are legit, near as I can tell. They're installed and seem fine. Just need them to hold me over until I can get a new set of Koni's.
Old Apr 4, 2016 | 01:20 PM
novaderrik's Avatar
Car: 86 Camaro
Summit's part number system makes it pretty easy to search for parts, with the first part usually being an abbreviated form of the manufacturers name. Jegs, on the other hand, uses numbers.. either way, it's easy to find parts on their sites if you know the manufacturer codes that they use and when you order from either of them the sticker on the box won't have their code on it but the receipt will.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
