Planning on getting new struts and shocks. What else should I do while Im there??????
Old Dec 20, 2001 | 08:56 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Im planning on getting new struts and shocks some time soon. Was going to lower also but may have been talked out of it and am still decideing. What else would should I do while Im down there in those areas??? What should I replace, inspect, or upgrade on the front end of the car???????
Old Dec 20, 2001 | 09:27 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
if'n you do lower it, replace the rubber spring pads when you have it apart.
Replace the tie rod sleeve adjusters with a good strong aftermarket set.
Idler arm
poly bushings (a-arm & sway bar)
'wonderbar'
Old Dec 20, 2001 | 09:36 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
Who sells the tie rod sleeve adjusters??
My car came with a wonder bar so that will save me a little money.
idler arm , dont know much about those, would a parts store one be all right???? Thanks
Old Dec 20, 2001 | 10:16 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
check out this link to Hotchkis.
Moog makes good stock replacement steering components and any auto parts store should care them
Old Dec 22, 2001 | 01:14 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Edelbrock also make the tie rod sleeves.
Old Dec 22, 2001 | 07:37 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey John, why you're in there, why not rebuild the front end if you haven't already? As already mentioned, replace the A-arm bushings, ball joints, tie rods, and sway bar bushings. If you have half of it apart, it's really not that far a stretch to do the rest of it.
Jegs carries Hotchkis adjustment sleeves for about $50, and like PF Flyer said, go with Moog parts for the tie rods and center link. A little more cash and time now means you won't have to tear it all apart later.
Energy Suspension should have all the rest of the bushings you will need. Let me know if you need a hand and I'll run up and help...just let it warm up a bit.
Later..
Old Dec 24, 2001 | 08:00 AM
gmanuel's Avatar
On my 83 there are bearings at the top of the stut towers. Change these all so. And do not forget to get a frint end alignment
Old Dec 24, 2001 | 08:58 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Axle/Gears: it's part of the transmission
go all out!!
here's my combo and I'm perfectly happy with it! I took my tired old '84 Trans Am's suspension and did away with it. I replaced it with: Eibach Pro-Kit 1.5" lower "progressive rate" spings,new front spring isolators from GM,PST polygraphite front end rebuild kit,KYB-GR-2 struts,strut mounts,and shocks,Hotchkis adjustable panhard rod and rear LCA's (non-adjust.) . I scraped the factory 15x7" firebird rims and went for the more desirable 16x8/16x8.25" 85-87 IROC rims w/245/50/16 Khumo Ecsta Z rated tires,I needed new rims because I broke one of the stock rims I also broke the axle.....so I upgarded to a 10bolt 3.73 auburn/richmond posi....it gets going just fine even with the 1.5 drop and no LCA brackets. not that I'll put those off for too long though,just need to find a good welder. the cool thing about it is,I did'nt use the most expensive of everything and I've got no complaints. handling is supurb! I've also replaced my "rag joint" steering coupler,power steering gear,pump & hoses,front wheel bearings. it's still the stock 2.5 turn ratio but that's not hard to fix,it's hard to be blue about such a thing when I've got the same cornering abilties as most of the newest stock T/As
make sure your car is squared up before you put your money into it,even though my car's a rat-box right now,it's one of the few thirdgens left with a square unibody. the total cost of all my parts was approx. $1200 ,not including 3.73,rims & tires (tires were $565 for all 4) labor cost.......busted knuckes,frustartion,foul language...$45 for alignment if you need install tips just email me.......have a automotive machine shop do the A-arm bushings!!
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
