HELP!! Will a Camaro Steering Column fit a Firebird?
Old Dec 20, 2001 | 11:55 PM
bzznczzn's Avatar
My 87 Firebird formula has a bad steering column and I found a great deal on a steering column, but it's a camaro column. Will they interchange? The guy only wants 50 bucks for it. Also, my Formula doesn't have cruise, but the camaro column does, will this effect anything? Thanks for the help.
Old Dec 21, 2001 | 07:00 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
it should fit and the cruise don't really matter, since it's just wiring
Old Dec 22, 2001 | 08:53 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The column will fit. No worrys.
But the turn signal switch will be different - cause the bird uses the same lights as brake and turn - the Camaro has independant signal lights. That means you will have to take the columns apart and swap turn signal switches. They will change over. Don't forget to change the lock cylinder too.
The cruise will not be an issue.
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
