Upgrading suspension questions
Old Dec 21, 2001 | 06:25 PM
un4givin89's Avatar
Perhapps I'm looking in the wrong places in my catalogs, or maybe just looking at the racing only ****. But does it usually cost over 300 dollars to upgrade my disc size? I want to replace my A arms with tubalar ones and I can't find any that are less than 800 bucks. Control arms 300 dollars, come one.
I keep hearing one of the most important and best mods is upgrading your supension. But who can afford it!
Old Dec 21, 2001 | 08:03 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Upgrading suspension questions
for the rear i used the following:
lakewood trailing arms #20140 $83.95
lakewood adjustable panhard rod #20440 $87.95
prices from summit.
as far as brakes go, yes it is expensive to upgrade. your replacing both calipers, rotors, bearings, sometimes hoses, and other miscellaneous pieces all at once.
Old Dec 21, 2001 | 10:05 PM
un4givin89's Avatar
what about the front? Control A arms, and such?
Old Dec 21, 2001 | 10:26 PM
mrr23's Avatar
Engine: 360 HSR
upgrading
i don't know about them. the problem with lower control arms is they have to have a seat to hold the spring. if any company makes them, they are probably still the same weight. maybe marginally stronger.
Old Dec 21, 2001 | 10:37 PM
un4givin89's Avatar
So we can't get tublar control arms
Old Dec 22, 2001 | 04:37 PM
camaro6spd's Avatar
If you want to convert to coil overs we can.....just look around, do a search and you will find lots.
Old Dec 22, 2001 | 07:19 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The stuff is out there but again it's not going to be cheap. Very few manufacturers with very little demand equals a premium price.
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
