Steering wheel not centered
Old Feb 2, 2016 | 01:46 PM
rubblerubble's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7L V8 L98
Okay guys. Just got my Formula 350 back and now trying to fix some of its issues.
It used to pull to the right and I thought it was just a misalignment until few months later, and a few shops around (those few told me they can't do it since this car needs a special tool for ligament) this one shop showed me what's wrong. The frame where the steering box is sitting on was cracked. So, had it fixed. Had a shop weld it back for me and it seemed like a good job, BUT, he told me something I don't remember exactly but it's about the steering wheel not being straight.
Now that the frame is welded, I took it back to the shop that saw the problem for an alignment.
They said the steering wheel cannot be centered. He believes 1.) Car got into a wreck and bent the frame 2.) Steering column didn't get splines lined up correctly 3.) steering column is bent.
He wasn't sure on which.
I asked them to try to align the car and get it straight as possible and so he did and it costed $70.
Didn't feel any difference when I drove it though.
Before adjustment:
Left front: Camber - 0.3*
Caster - 4.7*
Toe - 0.27*
Right Front: Camber - 0*
Caster - 5.1*
Toe - .35*
After adjustment:
Left front: Camber - .3*
Caster - 4.7*
Toe - .04*
Right front: Camber - .1*
Caster - 5.1*
Toe - 0*
The steering wheel, if driving straight, instead of pointed at 12, it's pointing at 10.
And I think that's way far off.
Sorry if it's the wrong thread. It's been awhile since I've been in the forums.
But please help me out.
Is it okay to just remove the steering wheel and put it back straight?
Or is there any way I could adjust it by messing with stuff by the steering box?
Thanks guys!
Old Feb 2, 2016 | 03:53 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Steering wheel not centered
Was the steering shaft changed out for a newer one?
Old Feb 2, 2016 | 08:30 PM
Engine: 5.7L V8 L98
He didn't mention changing it. I was under the car to check stuff down there earlier and it didn't look new.
Old Feb 3, 2016 | 08:45 PM
Engine: 5.7L V8 L98
Just saw that the arrows didn't line up. Maybe that's why?
Old Feb 4, 2016 | 12:45 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Those arrows are strictly for the purpose of properly installing the SIR coil (aka airbag clock spring) and have absolutely nothing to do with steering wheel alignment.
Old Feb 5, 2016 | 02:15 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If the front wheels are not absolutely strait when installing the steering wheel perfectly "strait up and down" there will be a problem.
I would start there.
Old Feb 5, 2016 | 07:14 AM
Lurbie's Avatar
Car: 89 Camaro
I haven't pulled an airbag wheel off in several years and have forgotten how large the holes are for the horn and airbag connectors. Is it even possible to install it that far out and still connect the horn and airbag harness?
Old Feb 5, 2016 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The top end of the steering shaft (as shown in picture) should have a witness mark on it. Same with the steering wheel, next to where it goes over the shaft should also have a witness mark.
I've seen them both as a hash or slash like mark and a dimple (round punch).
Line them up when installing the steering wheel. Then adjust the tie rods to center the steering. That's all there is to it.
In the picture there appears to be a mark on the top end of the shaft at about 11 o'clock. Out of focus so hard to tell.
RBob.
Old Feb 5, 2016 | 09:05 AM
Engine: 5.7L V8 L98
RBob.
Yeah, there were marks. There are missing teeth on the spline supposedly on 12 and 6 o'clock mark but whenever my wheels are straightened out the marks are on 10 and 4.
I installed a new steering wheel and broke the horn wire that came with the install kit. Couldn't figure out exactly how it should go. Lol
I had to buy a new steering wheel to get it back on straight. Can't put the same wheel back because the teeth doesn't line up with the mark on the splines.
Car drives straight now, except one I drive at speed, there seems to be play on the steering that makes me have to turn it counter clockwise by about an inch and a half to keep the car going straight, but I could keep turning it back and forth (pointing the wheel at 11:30 and 12 repeatedly) without the car moving drastically.
On low speeds, really low speeds, the steering is accurate. Weird.
How do I adjust the tie rods on this?
I know how easy it is with the other new cars but this one seems to have something different.
Thanks for all the response guys!
Old Feb 5, 2016 | 09:18 AM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
If you only moved the steering wheel it should not need adjusted again. and the play is most likely in steering box if the alignment place didn't tell you your tie rods or ball joints are worn out
Old Feb 5, 2016 | 09:23 AM
Car: 92 RS
Transmission: 700r
to adjust tie rods there is 2 pinch bolts on the sides of adjustment sleeve. loosen bolts and turn sleeve. but if you don't know what you are doing don't touch it.
Old Feb 5, 2016 | 10:40 AM
Engine: 5.7L V8 L98
Steering box? Is it the adjustment that's located on top of it, or could it be a failing box?
Would I need to take the nut off that's connected to the wheel?
I was the one who changed the tie rods before getting it aligned so I might have the idea. Not a super mechanic but I hope to figure it out.
Old Feb 6, 2016 | 09:20 AM
Car: 92 RS
Transmission: 700r
there is a adjustment on the box but i never worked on one. At my work we just replace them.
this is tie rod adjustment sleeve. loosen 2 bolts and turn the sleeve to adjust toe
Old Feb 6, 2016 | 09:26 AM
Lurbie's Avatar
Car: 89 Camaro
Just don't overadjust. You've got to leave enough thread in there that it won't pull out while you're driving!
Old Feb 7, 2016 | 11:23 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
what "special tool" is needed to do an alignment on these cars? i did mine in my garage with string, jack stands, a level, a carpenter's square, a tape measure, and a small pipe wrench..
Old Feb 7, 2016 | 11:30 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
^ At least as accurate as most alignment shops, and better than some....
Old Feb 11, 2016 | 09:48 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The special tool holds the strut tower in place while they get the caster/ camber set. Save having to repeatedly tighten and loosen the mounting bolts while adjusting. i don't think any car has had that type of adjustment for a while so not many places have the tool.
Zell1luk
Brakes
Jan 14, 2016 12:34 PM
'91CamaroRS
Jan 12, 2016 09:29 PM
soarestransam
Brakes
Jan 12, 2016 01:21 PM
'91CamaroRS
Jan 11, 2016 10:14 AM
