UMI SFC Visibility
Old Aug 3, 2016 | 11:12 AM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
UMI SFC Visibility
Are the UMI SFC visible from the side? I heard you can pinch weld them pretty much the entire length so that would seem to indicate they tuck up nicely, but I also heard that they are very similar to UMR and those have some gap. Spohn tubular hide the best IIRC but I don't want to weld round tubing. If you have a pic, please post it.
Old Aug 4, 2016 | 10:42 AM
UMI Sales's Avatar
Re: UMI SFC Visibility
Our trusty IROC test car.
You have to look under to see them. They're about 98% hidden and tuck in nicely.
Old Aug 4, 2016 | 05:44 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Looks nice, but who ever put that car on a cinder block needs to get hit in the head with that 4x4 block of wood.
Old Aug 7, 2016 | 03:06 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Thanks UMI man! That's exactly what I was looking for. Ill be getting a set shortly.
Old Aug 10, 2016 | 07:54 AM
Abubaca's Avatar
I was going to post a pic of my Iroc with UMI SFCs, but their pic shows it perfectly. That's exactly how mine fit.
Old Aug 10, 2016 | 12:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
I need these right now. UMI, do you have any specials going on or possibly scratch and dent ones?
Old Aug 10, 2016 | 01:27 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
I went with a set of UMI because they looked like good pieces and also didn't show when looking at it from the side of the car.
Old Aug 18, 2016 | 12:29 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
BottledZ28, I emailed UMI a couple weeks ago and they said the next sale was going to be black Friday. Last year they had a 10% off and free shipping for Thanksgiving.
Here's some prices:
Summit- $247.99 (but will beat a price by $1 lol)
Jegs- $239.99
LMPerformance- $229.00 (took $10 off to beat Jegs )
UMI- $283.40 (includes shipping to Central Illinois, $43.41)
UMI w/ 10% off and free ship- $215.99
All prices includ shipping.
I didn't contact Jegs but they price match as well and had a sale in January for $177.09 shipped which is definitely worth looking into. UMI also has them on eBay but its almost $300. In case anyone was wondering, UMI replied in under 4 hr, LMPerformance in 9.5 hr and Summit in like 2.5 days.
Old Aug 18, 2016 | 12:43 PM
BOTTLEDZ28's Avatar
Transmission: A4
Thanks for the info. I may wait until Black Friday and see what happens.
Old Sep 2, 2016 | 12:15 PM
UMI Sales's Avatar
We snuck in a Labor Day Sale I didn't know was going to happen. Now is the time to order!
thanks
ramey
Old Sep 5, 2016 | 01:33 PM
legaldisaster's Avatar
thanks
ramey
I just placed my order
Old Sep 5, 2016 | 07:47 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
I have UMI sfc's. I cannot imagine there are any better fitting more tightly tucked up connectors anywhere out there. They fit perfect. Very happy with them.
Old Sep 3, 2017 | 10:25 PM
A88GTANotchback's Avatar
thanks
ramey
I know this is old but I just figured I'd check and sure enough the sales back. Cost me a few bucks. But thanks!
Old Sep 21, 2017 | 05:37 AM
TeamPoisonOil's Avatar
Why?
Old Sep 21, 2017 | 06:21 AM
Saxondale's Avatar
Car: 84 Z
Originally Posted by TeamPoisonOil
Why?
Safety issue. The block will not withstand forward and backward movement as positioned in the photo. Also, if one block fails the rest will likely follow as the car drops and shifts.
Can be demonstrated by taking a single block and dropping it on a corner.
Old Sep 24, 2017 | 05:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I also have UMI connectors and have been very happy with them. They are one of the brands that box in the body side of the rear lower control arm mount. They do not hang low but they can be seen when you get down to eye level with the bottom of the car/floorpan. However, when you are that low you can see the exhaust, A arms, differential and rear sway bar so I don't see why it matters if you can see an aftermarket SFC.
My only suggestion to UMI is to offer a version of these that is for guys that run an exhaust down the transmission tunnel, ie long tubes. It would just be a mirror of the drivers side connector. I question the effectiveness of that dinky little connector that is to be used in conjunction with the stock exhaust.
Old Sep 25, 2017 | 09:52 PM
Abubaca's Avatar
My exhaust isn't quite stock, and I couldn't use that connector. Can't really scientifically "test" what the effects of not having it are, but I know the car will teeter on speed bumps.
Old Oct 5, 2017 | 07:58 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
abubaca... your exhaust setup looks just like mine. I havd the dyno-dons hearders, to his ypipe, then a welded on magnaflow spun cat, to the : echaust with my electric cutout mounted in just the same spot. however, I do not have a turndown like you do on the end of it. I have wanted to, but never did. not sure if you ran the car around without it and then with it and noticed a difference of noise/tone/sound wave reverberating etc?? I should get one, a nice polished or stainless one like you have. what brand is that?
jeremy iroc z28
Jun 3, 2016 02:03 PM
someone972
May 30, 2016 04:12 PM
BrianI
May 28, 2016 03:49 PM
BlackThunder
Exterior Parts Wanted
May 23, 2016 06:12 AM
90Iroc_Coup
May 9, 2016 01:36 PM
