Bent lower rad support
Old Oct 25, 2016 | 04:26 PM
Matt trans am's Avatar
Car: 1985 trans am
Alright so long story short.... Body shop I got my car painted decided to jack the front of the car up on the bottom of the rad support. It is bent in on the middle of the plate. Is there an easy way of fixing it. Nothing else looks damaged its just my peace of mind. Do i have to remove rad. This part has the lower valance that attaches to it. Its an 85 trans am.
Old Oct 25, 2016 | 06:03 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Bent lower rad support
So a body shop bent it and they aren't capable of fixing their mistake? pictures would help to see what we are dealing with.
-heat and a hammer will bring it back down
-a porta power set can be used to bend it back depending on the bend
-hell I even think taking the radiator and condenser out and jumping on the bend would probably get you close.
Old Oct 25, 2016 | 06:13 PM
Car: 1985 trans am
Cars at garage getting new suspension installed. I'm gonna give them ****. It cracked the fan shroud too. Nothing to be scared of structure wise? It looks more esthetic
Old Oct 25, 2016 | 07:08 PM
TylerSteez's Avatar
Engine: 383 stroker
Structure wise it should be fine but depending on the severity of the bend it could have cracked the metal in some points on the radiator support itself, not a big deal though, just bend it back and weld the cracks. I also wouldn't be surprised if your radiator cracked as well.
Old Oct 25, 2016 | 07:54 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Mine is bent in a similar manner as well. Happened before I bought it and didn't see it until I was under the car after I bought it. Hopefully there is an easy way to fix it. Just haven't had time to dedicate to figuring out a way to correct it. Maybe somebody with experience with this issue can chime in soon.
Old Oct 25, 2016 | 08:12 PM
Frame shop; just pull it back out. (hahaha)
Old Oct 25, 2016 | 09:21 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
long 2x4 and a sledge hammer will do wonders.
Old Oct 25, 2016 | 10:52 PM
Honestly, that was the line of thinking I was considering going with.
Old Oct 25, 2016 | 11:26 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
is that the car you bought from Jared?
seriously, they're usually pretty easy to straighten out. if its bent backwards, put a chain on it and wrap it around a tree, put the car in reverse and lightly give it some gas. its just thin sheetmetal.
Old Oct 25, 2016 | 11:41 PM
Yes, it is the car I got from him. The radiator isn't cracked so I don't think its too bad. Should be relatively easily fixable.
He still owes me for the broken front GFX, but I doubt I'll ever get paid for it. Just one of a few issues that he failed to disclose. But then again, some people have no sense of honor or integrity. I've given him several opportunities to correct the issue but he refuses to.
Old Oct 26, 2016 | 12:00 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
karma is a beatch! he should have made things right by now.
Old Oct 26, 2016 | 05:39 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I fixed one in the same shape with a 2x4 and a sledge hammer.
Old Oct 27, 2016 | 07:04 AM
83 Crossfire TA's Avatar
I bought one just like that. Mine was actually bent enough that the radiator was all bent up but surprisingly not cracked/leaking.
That's pretty much what I did with mine. I had a second radiator and found that it wouldn't fit/4th gen cooling fan swap wouldn't fit without doing something, so I literally took a few boards, a pry bar and a sledge hammer and pounded it back into place. It's not perfect but it's VERY close.
