Spindle question
Old May 24, 2017 | 07:32 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Spindle question
Anyone happen to know the angles of the strut mount on the spindle?
Old May 25, 2017 | 05:57 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spindle question
I have the blueprints somewhere, ill dig them out tonight
Old May 25, 2017 | 09:47 AM
SlickTrackGod's Avatar
On Probation
The steering angle inclination is aprox 13*. It could be fudged a little more or less based on slop of the angle between the strut and spindle bolts when tightened.
Old May 25, 2017 | 01:37 PM
Dean, the degree symbol is:
Hold down the Alt key, type 0176 on the num pad with NumLock on, and let go of the Alt key.
Works in ANY program, because it's an operating system function, not an app one.
That's on Windows and *x. Not sure about Scrapple. I avoid the Empire. I may just be a blockade runner, but I can outrun any Imperial cruiser.
Just for fun, try other combinations after the 0.
Enjoy.
Old May 25, 2017 | 04:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
If deans number wasn't what you were looking for, the mount on the spindle is angled on 2 axis. From vertical off the snout, its 16.5171 degrees inboard and what appears to be 50 degrees of rotation from vertical.
Old May 25, 2017 | 05:45 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
thanks!
wow.. my estimation was close. I estimated 45 and 12.
Old May 25, 2017 | 08:41 PM
On Probation
I actually had no clue on the spindle numbers itself. Impressive info. Rarely do I see anyone come up with such detailed specs....Especially when I've ever ask on a board for help.
Old May 25, 2017 | 09:35 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I think it was Costas on FRRAX that had the blueprint.
Old May 25, 2017 | 09:40 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
It was. He was selling prints 2 years ago instead of scanning into a pdf.
Old May 25, 2017 | 11:09 PM
On Probation
Try fabricating a steel prototype spindle that would accept a 4th gen hub. This would be far easier and safer direction to go.
Once you cut and alter and cut and alter ,etc etc, etc.....you can fine tune the steering arm and overall specs of the spindle then pinpoint the finished product for possible billet machined piece out of 7075.
Then fab it into a drop spindle application.
This would sell like hotcakes.
If I had time and the machinery I would be working on this as well as a few other goodies I have ideas on.
Old May 26, 2017 | 05:30 AM
83 Crossfire TA's Avatar
A $$$ piece for 3rd gens sell like hotcakes? I'm not sure the market is there yet. it's long been a problem with 3rd gen products, if you put any real $ into them it's very hard to get the typical 20something broke 3rd gen owner to get off their wallet and spend money on them. It seems like most of us that have been around them long enough to be nearly 2x that age and still tinkering with them are more likely to build our own then spend $$$.
Old May 26, 2017 | 05:47 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
true however when it comes to something like a spindle that is impractical to fab up for a one off unless you work or own a machine shop. I would spend to buy them the question is price point... My guess is probably $400-500 is too end of what they could sell at. Question is can it be made for that....
Old May 26, 2017 | 06:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Yup, that's where I got my copies.
Old May 26, 2017 | 08:40 AM
rgauder's Avatar
Car: 1987 Trans Am
Any chance on getting a copy of this drawing?
Old May 26, 2017 | 09:53 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
I paid more like $700+ for the RR Racecraft drop spindles. And they make spindles for multiple applications. They are not a one-off shop.
To match their quality in a less experienced shop, would cost more. I won't even mention liability.
Old May 26, 2017 | 10:50 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
My line of thinking is for a fabricated steel spindle that the separate pieces would have 'mortise and tenon' joints that would then be stick welded to structural specifications. More surface area and more safety if a weld did crack.
The front face would be up to half inch thick (a tad bit overkill at this point). The strut mount would be the full 33mm thickness.
The design right now is a 2" drop.
Old May 31, 2017 | 03:58 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Roughly where I'm at now.
Attached Thumbnails Spindle question-_spindle.24946180-66ec-4093-ac07
Old May 31, 2017 | 04:37 PM
rgauder's Avatar
Car: 1987 Trans Am
Just curious why you are going with a sealed bearing hub rather than the "snout" like stock spindles?
Looks like you are doing good work.
Old May 31, 2017 | 06:20 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
I want the wheel speed sensor, ease of replacement and such, use of modern brakes, etc. Plus, creating a correct press in portion is a hassle i dont want..haha.
I need to refine the strut mount portion and move it a over a touch, finish the steering arm, etc.
Old May 31, 2017 | 06:24 PM
rgauder's Avatar
Car: 1987 Trans Am
I figured it was for the use of the speed sensor. I don't know what it has to do with the use of modern brakes though. Wouldn't adapters for the caliper mount take care of that, just like the standard spindles?
Old Jun 1, 2017 | 12:20 AM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
I can also design it so I dont need an adapter.
Old Jun 2, 2017 | 04:40 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
any recommendations for steel to use? I would LIKE to stay away from chromoly
Old Jun 6, 2017 | 04:56 PM
turd_gen's Avatar
Car: 1985 Trans Am
If it were me, my go to would be 4140 or 4340. Cheap, strong, plentiful and easy to machine.
