17X9.5 or 17X8.5 wheels up front?
Old Jan 2, 2002 | 07:21 PM
Raptor Pilot's Avatar
Should I use 17x8.5's up front for better clearance? or will 17X9.5's work just as well up front on a 3rd gen? I am using 17x9.5's out back. Any cornering,etc. performance sacrificed by using an 8.5 up front?
Old Jan 3, 2002 | 09:12 AM
Z28DJP1987's Avatar
I am using 17x8.5 on all four corners with 245/45/17zr tires. No problems and they stick like clue in the corners. Also if you keep the same width you will be able to rotate the wheels and tires,
I only use spacers on the front. The car is 87 IROC.
Old Jan 3, 2002 | 03:12 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Raptor,
if I were you i'd go with the smaller.Ive got 9 x 18" front and 10"x18"rears and i find the 9"s "tramline" on any road imperfections.Look cool though!!
cheers pm
Old Jan 3, 2002 | 09:02 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
powermite, those are some awesome rotors! what kinda brakes do you use? im stuck with the stock brakes and im sure its quite a step up with what you use.
Old Jan 4, 2002 | 09:45 AM
powermite's Avatar
Car: Transam
Im using a Baer Kit front and rear.I cant praise Baer enough.The kit came ready assembled and was fitted in a day with no other modifications needed.Also they performed even better than promised
Cheers
powermite
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
