Rear Spring Spacers
Old Dec 6, 2017 | 06:47 PM
jbates346's Avatar
Rear Spring Spacers
I have an '88 IROC and just lowered my car with the ST Suspension springs. Looks pretty good! I just want to get the rear up a little higher. I was thinking about using a rear spring spacer to do this. I heard that whatever size spacer you use, the amount of lift double. For example, if you use a .5" spacer it'll lift the car about 1". Does anybody have experience with this? Is that accurate?
Old Dec 6, 2017 | 08:55 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Rear Spring Spacers
I used the rear isolators I bought from a dealership a few years ago. They were for a '98 T/A and lifted the rear just a smidge so that it had a more aggressive stance to it.
Old Dec 7, 2017 | 06:59 AM
Not true.
LOOK AT the parts in question; you'll observe that there is NO leverage or mechanical advantage anywhere in it, unlike front springs, in which that "hearing" is less inaccurate.
.5" spacer = .5" lift
Old Dec 7, 2017 | 06:55 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Any spacer you put between the spring and chassis will lift the car the exact amount as the spacer size. Theres nothing to double because the rear springs are more or less straight up and down. If you want it 1/2" higher in the rear, a 1/2" spacer is what you want.
Old Dec 9, 2017 | 08:54 PM
jbates346's Avatar
I appreciate everyone's feedback. That's what i was thinking I just wanted to be sure before I bought the parts.
Blacksunshine....your stance looks awesome. That's about what i'm going for. What size isolator did you use?
Old Dec 9, 2017 | 11:49 PM
It was the stock isolators from a '98 Trans Am. IIRC, they are ~3/4-1", but don't quote me on that.
Old Feb 2, 2018 | 08:26 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
That’s about right. The 4th gen isolators add about 1” of rear static ride height compared to the 3rd gen isolators. I used Eibach 1” lowering springs on all 4 corners and then swapped the rear isolators to 4th gen to bring the rear back to stock ride height. Gives the car a nice forward rake.
SnotRkt
Jun 13, 2015 07:42 PM
UMI Performance
Nov 6, 2014 09:10 PM
mike graycar
Feb 12, 2004 03:03 PM
james_85Z28
Oct 15, 2003 07:47 AM
espirocz
Dec 18, 2002 08:34 PM
